[FMF] Free Model F - Miscellaneous
idollar
i$
01 Jan 2025, 04:09
Please refer to the mother GB thread which can be found here
Introduction
Note: this post will be updated. As such it shall be considered work in progress. A change log is shown at the end.
Last change 2025.01.01 (yyyy.mm.dd)
The Sensing PCB is considered priority 0+, being 0 the highest priority.
The purpose of this thread is to maintain a comprehensive list of small COTs components (e.g. screws) to ensure a complete BOM list.
Constraints
  • None identified
Alternatives to be considered
  • None identified
--- change log (yyyy.mm.dd) ---
2025.01.01 - initial version
2025.01.01 - updates to align to overall project concept (e.g. priorities, constraints, options added)
idollar
i$
01 Jan 2025, 13:49
Reserved for miscellaneous items list
idollar
i$
01 Jan 2025, 13:49
