Heavier beamsprings?
vyquad
- Main mouse: G502
- Favorite switch: IBM Capacitive Buckling Spring
im wanting to get a beamspring the force curve is wayyyy too light for me. a stock model f alone is too light for me. So does anyone have the specs of a beamspring spring to be modified or produce new springs? im wanting the force curve to a boba u4t 62g if possible
SOTGO
- Main keyboard: ANSII Mod F AT
- Main mouse: Logitech MX518
- Favorite switch: Micro Switch SW
It might be hard to make the shape of a beamspring force curve match the shape of another force curve, but you could make them more tactile by manufacturing a replacement beams spring that is thicker than the original or by finding a stronger external coil spring, although that might be hard given the uncommon shape.
vyquad
- Main mouse: G502
Dont really need the exact force curve, just the general weightSOTGO wrote: 17 Jan 2022, 05:51 It might be hard to make the shape of a beamspring force curve match the shape of another force curve, but you could make them more tactile by manufacturing a replacement beams spring that is thicker than the original or by finding a stronger external coil spring, although that might be hard given the uncommon shape.
