Keycaps, because you can never have enough. Or something like that. MX-compatible, obvs., though Model M compatible would definitely be an option.
A current project I'm doing involves retyping bits of Cyrillic and I've decided that yazhert (i.e. ЯЖЕРТetc) is my preferred layout. I suspect an unconscious bias to whatever is least available, so of the few Cyrillic keysets I've found, none caters for that. Just to make sure it's an impossibility, it would also need to be ISO, and also also need to be UK ISO, so none of that faffing about with reversing " and @.¹ And it would need to be SA profile or similar: I hate non-sculpted keys like DSA as much as I hate the ANSI layout. Of course much of that is irrelevant if I can find caps for my M, so that's an option.
Oh, and they would need to be double-shots, nice heavy ones in fancy colours that I'm ambiguous about, be available tomorrow and cost about 23p. I think that guarantees impossibility.
Any suggestions of what options might be available to me? I suspect for MX caps I'm going to need to sacrifice things like colours, weight and definitely double-shot, nobody is going to do that for a one-off. I'd prefer not to sacrifice SA (or similar) but I think I'm going to be looking for at best dye-sub so that'll limit me to dark-on-light.
Edit:
[1] This also depends on me figuring out how to customise Linux Mint's available keyboard layouts as used by Cinnamon, which is a problem for elsewhere, but it seems less than keen to divulge its secrets. That said, I may be migrating away from Mint for various reasons anyway (well, for one reason, which is systemd), just to make it even less relevant.
