OG Cherry set
phinix
19 Jun 2019, 15:07
Is it hard nowadays to get this old school doubleshot Cherry set?
I have a moogle kit, just after an original set, like with 1.5u mods and 7u spacebar etc...
samuelcable
19 Jun 2019, 15:27
phinix wrote: 19 Jun 2019, 15:07 Is it hard nowadays to get this old school doubleshot Cherry set?
https://www.ebay.com/itm/283504850728/
phinix
19 Jun 2019, 15:54
samuelcable wrote: 19 Jun 2019, 15:27
Cool, thanks.
What that C6 means? Do you know?
Looks like some caps are different, I hope most will be authentic...
samuelcable
19 Jun 2019, 16:32
phinix wrote: 19 Jun 2019, 15:54
Cool, thanks.
https://www.ebay.com/itm/Set-of-used-Vi ... 3504844020
actually, this one is a little better since all the caps are from the same board i think. "c6" and in this case "b1" is just the seller's way of labeling or grading them, i think. the seller is on this forum
phinix
19 Jun 2019, 23:58
I wonder if these are really worth €40.
I would need to wash them in hydrogen peroxide...
20 Jun 2019, 11:17
You will have a very hard time to get them cheaper than that without scouring eBay for a long time.
phinix
20 Jun 2019, 12:48
scottc wrote: 20 Jun 2019, 11:17 You will have a very hard time to get them cheaper than that without scouring eBay for a long time.
OK, cool, thanks for confirming it.
I don't know its value, that is why I wanted to ask:)
sl70309
22 Jun 2019, 18:34
GMK 9009 has same looks.
Return to “Want to buy”
