Hello guys, my name is toty! I'm new.
I've been told at r/MechanicalKeyboards to ask over here about this keyboard.
I'm also new to meks (only 2 so far) so when I first saw it laying around my IT department I thought it was a vintage mek but at reddit someone said it's not a mechanical one.
Could anyone give my a hand with this?
https://imgur.com/a/8YFy8hx
Thx!!!!
IDENTIFY COMPAQ keyboard
- Myoth
- Main keyboard: IDB60
- Main mouse: EC1-A
- Favorite switch: Cap BS
Welcome !
As for the board, it's wiki/NMB_dome_with_slider, which is not a mechanical keyboard. Unfortunately.
Also, next time you have a keyboard you're trying to know more about, be sure to post it in the right thread, which would be this one : viewtopic.php?t=10405 .
Enjoy your stay !
Enjoy your stay !
Anakey
- Main keyboard: Planck
- Main mouse: Cyborg Rat 7
- Favorite switch: Alps skcm white
Hi They were correct in that it is not mechanical but is a dome with slider. looks like it used laser engraved keycaps then infilled though it has seen so much use that some of the keys have worn through the engraving. I would say that there is not much point in keeping the board due to the 20+ years of use it must have had to wear that much through the keycaps
ultra_reader
- Main keyboard: poker 3
Thx Myoth!Myoth wrote: Welcome !
Enjoy your stay !
Coming from almost 20 years of using membrane keyboards everytime I see something different I'm bound to think it's mechanical.
I thought those were alps switches hahaha!!!
About the new thread I'm sorry I thought the other one was only meant to that specific question.
You can close this one If you like having cleared my doubts.
Thank you!
ultra_reader
Anakey wrote: Hi They were correct in that it is not mechanical but is a dome with slider. looks like it used laser engraved keycaps then infilled though it has seen so much use that some of the keys have worn through the engraving. I would say that there is not much point in keeping the board due to the 20+ years of use it must have had to wear that much through the keycaps
Thx Anakey!
Is it worth to keep it? Perhaps doing some cleaning and finding new keycaps I could give it a second life... it's not like is full membrane haha!!!
- Myoth
- Main mouse: EC1-A
Alps huh ? haha I fell for the exact same trick when I began, my friend has now that board I fell forultra_reader wrote:Thx Myoth!Myoth wrote: Welcome !
Enjoy your stay !
Thank you!
The wiki is probably your best source of information, here it is, wiki
Next time, you have a similar question, this article might help you a lot
Anakey
The problem would be finding replacement keycaps as they do not use a dtandard mount it would be hard to find replacement ones that will be compatibleultra_reader wrote:Anakey wrote: Hi They were correct in that it is not mechanical but is a dome with slider. looks like it used laser engraved keycaps then infilled though it has seen so much use that some of the keys have worn through the engraving. I would say that there is not much point in keeping the board due to the 20+ years of use it must have had to wear that much through the keycaps
Thx Anakey!
- abrahamstechnology
- DT Pro Member: 0212
Dremel it out, stick a custom PCB in there?
(I've been actually planning to do this with a Gateway rubber dome keyboard but haven't gotten to it yet)
ultra_reader
Hello abrahamstechnology! Ohh unfortunately I'm not that pro yet! I barely desoldered my pocker 3 to fix bad stabs (it went out really well though) but going through the whole process of dremel it out, finding a suitable pcb, keycaps... not for now.abrahamstechnology wrote: 08 Jan 2019, 02:39 Dremel it out, stick a custom PCB in there?
Maybe some time in the future!
Anyway Thanks for your advice!
- Howard81
- Main keyboard: IBM Model M/F
- Main mouse: Not fussed
Those are actually fairly decent keyboards - they have a decent weight to them thanks to a giant metal plate in the casing and don't feel too bad if they're fairly low mileage.
