Model F PrtSc
- digital_matthew
- Main mouse: It's a Secret.
Hello. I recently got an IBM Model F XT from the recycling center. I'm running it on my PC with a Soarers converter and it works great. The only problem is I can't get the Print Screen to work. I've tried Shift, Ctrl, Alt, and Num Lock, but all I get are asterisks. Any help would be appreciated. Thanks!
- Myoth
- Main keyboard: IDB60
- Main mouse: EC1-A
- Favorite switch: Cap BS
Soarer's converter does not support it, though you can modify it. I have a link somewhere, I'll try to get it for you ASAP, it explains it all very well and programmability of the Soarer's converter.
- digital_matthew
Thanks, Myoth! I tried remapping the keys from some post on Reddit, but I really couldn't follow it. If I could remap some other keys to what I need, then this gem could truly be my daily driver.
- depletedvespene
- Main mouse: Logitech G700s
- DT Pro Member: 0224
The * key on your F XT keyboard is probably sending the PAD_ASTERIX scan code. You will probably have to do a macro to bind LSHIFT+PAD_ASTERIX to PRINT_SCREEN (and another one so RSHIFT+PAD_ASTERIX will do the same).
