Roost Laptop Stand
seaworthy
11 Jan 2016, 05:36
This is a short review of a laptop stand that I have recently purchased. I have no affiliation with the manufacturer other than being a satisfied customer.
In that nearly everyone here who uses a laptop would probably rather be typing on an external keyboard than on the native laptop keyboard, I would guess a fair amount of people might have interest in a laptop stand of some sort. Along with the ability of putting your laptop at the same height of an external monitor, laptop stands do marvelous things for posture and reducing neck and back strain.
I use a Macbook Pro and became familiar with TwelveSouth.com’s sturdy and Apple aesthetic-matching aluminum stands. I have one of their older fixed-height models. It’s battle-ship strong but not exactly light, even though constructed from aluminum.
I’ve not used their newer HiRise model, and even though it now has a height adjusting aspect, I was looking for something much lighter and mobile but just as robust.
I bumped into a great solution on Kickstarter—the Roost Stand. I’m not a huge Kickstarter advocate—I’ve been disappointed or outright burned as many times as I’ve been satisfied. But this product is the ideal solution for laptop users who would much rather use their mechanical keyboard(s).
Reportedly the first version of the Roost was very well liked and successful, but people wanted height adjustments and the ability to close their laptops while in the stand. This is the designer/engineer’s 2.0 version the product. I think he was an aerospace engineer previously and has experience working with materials that are necessarily specified to be strong and light.
The Roost Stand delivers on those premises. It’s about the size and weight of the cardboard tube inside a roll of paper towels when collapsed (okay, I exaggerate the lightness—it’s .38 pounds or 170 grams). You grab and pull the feet horizontally to deploy the stand. The “chin” of your laptop is rests in two innovative pivoting grips that hold your machine securely even when you tilt the stand 45 degrees either way (as if that’s a feature we’re knowingly searching for…).
Lately I haven’t had to travel much, so I use it at home on my treadmill desk and at the kitchen table for my work while my kids do homework. It’s the right motivation for me to take every opportunity to plug into a mechanical keyboard (like dull chiclet keys aren’t enough). It tucks into your every-day carry like three Slimjims. The design is the most innovative tech product I’ve ever seen that doesn’t require a battery or a cord to plug in. Yet it's simple and just works (well).
I know it sounds like I’m the vp of sales so I’ll stop and just say it’s worth beyond what you’ll pay to acquire it if you want to check it out for yourself. I think it still has a “launch” price of about $60. I’m not sure if it’s appropriate to post a link or not—just google “Roost Stand” if interested.
shreebles
Finally 60%
11 Jan 2016, 08:08
Looks very cool but I find it hard to justify 60$ for a laptop stand.
I found that a TKL is pretty much exactly the width of my 15" Laptop so I just put my Mech on top of the laptop across the keyboard. No accidental presses since it's resting on the side panels and not the laptop keyboard.
seaworthy
11 Jan 2016, 08:28
Right. Most of us tend to spend a bit much on his habit/hobby. I get the simplicity of just placing your mech right on top of your laptop keys. I might start trying that a bit myself as I spend a lot of time in bed (too much time from an illness) typing / working, and I hate typing on my laptop. Putting the mech right on top might work in bed with my my knees propped up.
However, the benefit of a laptop stand is the posture correction. I was really skeptical that it would make any difference, but holding your head level instead of hanging it down to view your laptop on a desk makes a very noticeable difference after 20 minutes. Biggest benefit is for your neck.
stratokaster
20 Jan 2016, 21:51
seaworthy wrote: However, the benefit of a laptop stand is the posture correction. I was really skeptical that it would make any difference, but holding your head level instead of hanging it down to view your laptop on a desk makes a very noticeable difference after 20 minutes. Biggest benefit is for your neck.
I second this. Even if I use the laptop on its own, it quickly makes my neck stiff. If I use it with a second display, my neck starts to hurt because two displays are not level and I need to constantly adjust my head's position depending on what I'm looking at. Since getting a high-quality stand (I use RainDesign mStand) my neck and upper back are no longer stiff and painful after spending 8 hours at the desk.
TuxKey
LLAP
30 Jan 2016, 09:17
I'm really a big fan of the Roost laptop stand..
I had the Roost 1.0 for over a year now. And just a couple of weeks ago i got my kickstart Roost 2.0. :geek:
After looking at all other stands this one is the only one that i like..
it's light portable and does what it needs to do..
When i'm just browsing at my desk and my macbook pro is just shilling at 50 degree Celsius and i don't need a second display
i keep the lid closed (only possible with model 2.0)..
When i'm working on my multiple vm's i open up the display, to keep things cool crank up SMC fan control and enjoy a second monitor..Adding a small keyboard with no Function row helps bring the laptop closer to you and functions a good monitor..
Also version 2.0 is hight adjustable..
Roost 2.0 closed lid
seaworthy
30 Jan 2016, 17:12
It's ongelooflijk good, isn't it!
TuxKey
LLAP
30 Jan 2016, 18:31
seaworthy wrote: It's ongelooflijk good, isn't it!
hahahha yah ongelofelijk goed Best laptop stand ever.. :D
I'm very happy with it..One of the best kickstart projects ever..
on the go different desk open Roost 2.0 Keyboard FC660C
30 Jan 2016, 18:44
Ongelwhat?
My image search makes no sense!
TuxKey
LLAP
30 Jan 2016, 19:07
Ok ok ongelofelijk is dutch for incredible ...hahaha sorry guys..
seaworthy
30 Jan 2016, 19:15
"ongelofelijk" (sort of sounds like: on-ha-loaf-a-lick) is the Dutch word for "incredible," but they say it in a way that is far superior to "incredible"--has a real onamonapia quality with a lot of glottal, back-of-the-throat stuff. The connotation is similar to how we might use "unbelievable."
I used to work for Dutch software company Baan (a million years ago), and when I'd say dumb stuff in meetings they'd raise their eye-brows, look at each other, and disdainfully whisper "ongelofelijk" like you would when a goofy American says stupid things.
Return to “Reviews”
