- Wild Duck
- Main keyboard: Model F62
- DT Pro Member: 0000
Contact:
21 Nov 2017, 18:04
Sponsored by:
Vote in the final round of this category to win a
MasterKeys S, a Knop Mini, and a MasterMouse from Cooler Master!
Nomination rules:
Please suggest nominees for the best input device related project or innovation in 2017. This can be a group buy of something designed by the community, a personal project, a switch innovation, etc. You have to give a short motivation for each suggestion. The project or innovation must be newer than November 26, 2016 to qualify for this year's DTAs. You cannot nominate your own projects or innovations.
Current suggestions:
- HaaTa for his force curve measurements, I've found them to be super useful
Already ran last year
- Click bar on Kailh Box switches, best sound for a clicky mx switch to date. Kalih Click Bar is on another level of clicky.
- PlastikSchnittstelle's SKBXX solid bent alu case made in Germany (60%+75%)
- XMIT and his MX compatible hall effect boards having success on massdrop with R2
- emdude's Xwhatsit/CS-Compatible IBM 3277 PCB, cool community project, completed, available, building on stuff that was already there ... and fun to read and follow
- Orpheo's DIY numpad, sized to match 60%, awesome keyboard case, made of wood
- QMX Clips: a truly efficient damping method for MX switches that's user friendly (no switch opening), works for both downstroke and upstroke, and doesn't cost an arm and a leg.
- DMA's "CommonSense" project for bringing Capacitative keyboards controllers into the modern world. It's an open-source project that uses a $10 off-the-shelf devkit to provide ALL the circuitry needed to drive ANY Model F or Beamspring.
- _red_ with his work in the pcb for the barn find IBM 3741 Data Station. He is doing a lot of hard work on it and it's making good progress!
- The Level, a keyboard project nearing completion by Kevin (/u/thesircheddar on reddit). I applaud his determination, and his willingness to compromise on his dream to make the design have a greater appeal to those who expressed interest in his project, plus working hard to make it as affordable as possible through clever design choice (such as the open USB slot which reduces milling costs and re-alignment costs significantly).
- Mattr567's Alps Plate Spring G80-1000
- Shout out to /u/b-randen on Reddit for the bumpin' Seattle meetup last July!
The first round ends on Sunday 26 November, 19:00 UTC.
21 Nov 2017, 19:25
I nominate HaaTa for his force curve measurements. I've found them to be super useful
Chert902
21 Nov 2017, 19:30
Click bar on Kailh Box switches. Best sound for a clicky mx switch to date.
Rimrul
- Main keyboard: G80-3000LQCDE-2 w/ SKIDATA+
- Main mouse: Logitech B100
- Favorite switch: M Buckling spring, so far
- DT Pro Member: 0247
21 Nov 2017, 19:41
webwit wrote:
Nomination rules:
Please suggest nominees for the best input device related project or innovation in 2017. You have to give a short motivation for each suggestion. The project or innovation must be newer than November 26, 2016 to qualify for this year's DTAs.
Chyros wrote: I nominate HaaTa for his force curve measurements. I've found them to be super useful
seebart wrote: I forgot about this one; I'd hereby like to nominate HaaTa for his elaborate force curve gauge project since it provides very important data about mechanical keyboards on a very professional level to us. HaaTa went to great lengths with this as you can see here:
photos-f62/the-problem-with-mechanical- ... ml#p339559
Rimrul wrote: 2nd place: HaaTa's force curve gauge
HaaTa was tired of subjective reviews, so he took matters into his
own hands. The result is a completely objective measurement system with high precision, accuracy, and granularity. Accurate force curve graphs will soon flood the Deskthority wiki!
I'm not sure HaaTa's force curve measurements are eligible, as they where nominated for this category of the DTAs on November 20, 2016 and got the second place in the DTAs 2016.
- Offtopicthority Instigator
- Main keyboard: Rotation
- DT Pro Member: 0061
Contact:
21 Nov 2017, 20:02
Rimrul wrote: I'm not sure HaaTa's force curve measurements are eligible, as they where nominated for this category of the DTAs on November 20, 2016 and got the second place in the DTAs 2016.
Good point.
21 Nov 2017, 20:14
Rimrul wrote: webwit wrote:
Nomination rules:
Jeez, has it been that long?! xD
recon8659
- Main keyboard: Pok3r
- Main mouse: Logitech g502 Proteus Core
- Favorite switch: Clicky/Tactile Alps or MX, Buckling Spring
21 Nov 2017, 20:26
KAILH clickbar for finally making a really nice modern clicky switch.
XMIT and his MX compatible hall effect boards having success on massdrop.
__red__
- Main keyboard: 4704
- DT Pro Member: 0186
21 Nov 2017, 22:50
I'd like to nominate DMA's "CommonSense" project for bringing Capacitative keyboards controllers into the modern world. It's an open-source project that uses a $10 off-the-shelf devkit to provide ALL the circuitry needed to drive ANY Model F or Beamspring.
The huge advantage of CommonSense over some of the other techniques is that CommonSense allows you to configure sensitivity PER PAD instead of globally (xwhatsit) or not at all (original). This flexibility means that PCB designers don't have to be as "stringent" as before really opening up options for future designs.
In summary, it's awesome and you should vote for it
__red__
22 Nov 2017, 01:42
Wasn't me, was JP! (I just made him a pcb for it) and I nominated him for ancient find.
subcat
- Main keyboard: HHKB Professional
- Main mouse: Zowie EC2-A
- Favorite switch: Topre
22 Nov 2017, 02:11
i'd like to nominate emdude and co.'s work on the IBM 3277 mini pcbs
- DT Pro Member: 0194
Contact:
22 Nov 2017, 03:40
__red__ wrote: Wasn't me, was JP! (I just made him a pcb for it) and I nominated him for ancient find.
You didn't just make it, you designed it without even knowing of emdude's work. Although most folks have been going with Xwhatsit's with their beamsprings I think your project helps pave the way for others who may want to experiment with the Common Sense controller.
workshop-f7/ibm-3741-data-station-keybo ... ml#p391623
__red__
22 Nov 2017, 07:37
Then join me in supporting my nomination for DMA, the guy who actually wrote CommonSense.
The principle of using an ADC to do the measurement has been independently `discovered` and prototyped by numerous people on this forum. DMA was the first person to be successful in its implementation.
flehrad
- Main keyboard: Filco MJT2/Ducky Legend
- Main mouse: Plugable GM
- Favorite switch: MX Green
Contact:
22 Nov 2017, 08:57
I'd like to nominate The Level, a keyboard by Kevin (/u/thesircheddar on reddit).
He had originally started the project for his final year project at college, but due to his project group refusing to have anything manufactured outside the USA, he took it upon himself to follow through his vision. The project started with his own ideas, but through consult with the community, it underwent a large number of revisions and changes, resulting in a different keyboard than he originally imagined, but it still retained the spirit and basis of his original intent.
While the project isn't 100% completed right now, it is in final prototyping before moving to the buying phase.
- DT Pro Member: 0011
22 Nov 2017, 10:03
flehrad wrote: I'd like to nominate The Level, a keyboard by Kevin (/u/thesircheddar on reddit).
Here is a link to the Reddit thread. It is spelled with weird unicode characters so it was not super-easy to find...
All I see that is special is that it uses an acrylic plate in a heavy slab of a case.
The PCB is already available from Sentraq.
If it has not been available by now, it shouldn't be eligible anyway ... or?
Findecanor on 22 Nov 2017, 10:13, edited 1 time in total.
flehrad
Contact:
22 Nov 2017, 10:07
Fair enough, I've never been involved in the DTAs, so first time to learn everything about it!
Wingklip
- Main keyboard: IBM 3178 Model F C2
- Main mouse: G502 Logitech Proteus core
- Favorite switch: Beam/plate spring
22 Nov 2017, 13:38
Nominate Model MF
Khers
- Main keyboard: LZ CLSh
- DT Pro Member: 0087
HeroXLazer
- Favorite switch: Fosen
22 Nov 2017, 17:11
The Kalih Click Bar is on another level of clicky.
koduh
- Main keyboard: Clueboard
- Main mouse: M570
- Favorite switch: Jailhouse Blues
22 Nov 2017, 17:28
Kailh click bar def getting my vote.
- Main mouse: MS IMO 1.1
Contact:
22 Nov 2017, 23:05
Everyone who's nominating click bar switches has spent time using them, I assume? It's just that, to my knowledge, very little has been said about the experience of using them, and what I did read was negative. If people are actually using them and viewing them favourably, then that's good.
sachin3767
- Main keyboard: IsoFox OG
- Favorite switch: 67g Zealios
23 Nov 2017, 14:48
+1 QMX Clips but I wonder whether the credit should go to ZealPC for creating these?
chuckdee
- Main keyboard: Clueboard/RS Ver.B
- Main mouse: Logitech g900
- DT Pro Member: 0151
23 Nov 2017, 15:35
Not sure if that applies, since R2 is on Massdrop and could be nominated for the changes.
- Wild Duck
Contact:
23 Nov 2017, 15:51
Ok, added, the voters can decide.
