I did not even know they still made this stuff but apparently they do.
http://www.amazon.co.uk/Ambersil-Amberc ... B002SQIJ7K
Last time i used it was over 13 years ago now in the win 2000 beige box days, it was always very good at cleaning off dirt and tobacco stains and the smell is wonderful.
Does anyone still use this stuff ? Ever tried it on keyboards as apparently it repels dust.
I don't recommend you try it but the stuff we used back in the day burned at a very low temperature so if you where quick you could light it in your hand and make like you where throwing fireballs.
This bottle may be off as you don't get much foam with it and its quite wet, i remember it was more like shaving foam, still does a good job of cleaning however.
