Soldering iron -
- ShivaYash
- Main keyboard: HHKB Pro 2 BT
- Main mouse: CH Products Trackball Pro
- Favorite switch: Topre
Hello chaps,
I'd like a soldering iron - but the options are far and wide.
I like Antex as a brand - but unsure of what wattage to go for. Do such items come in variable wattages?
Mainly I'll be doing small home electrical stuff, I very much doubt I'll be desoldering and soldering my KBs, although my FILCO NUMPAD could do with one switch being replaced.
Suggestions sought.
Suggestions sought.
- DT Pro Member: 0167
It all depends on how much you have to spend. I would never get one that's just on the end of a wire you need a soldering station, even if its just a cheap one its better than the ones on the end of a wire. The most important thing is a good quality tip, even if you buy a clone you should buy a real tip for it.
- DanielT
- Un petit village gaulois d'Armorique…
- Main keyboard: Various custom 60%'s/HHKB
- Main mouse: MS Optical Mouse 200
- Favorite switch: Topre/Linear MX
I have a CFH 15W soldering iron, I soldered and desoldered tons of stuff, it's really good and cheap if don't want to build "spaceships". It works also fro SMD if you have a steady hand.
- Nuum
- Main keyboard: KBD8X Mk I (60g Clears), Phantom (Nixdorf Blacks)
- Main mouse: Corsair M65 PRO RGB
- Favorite switch: 60g MX Clears/Brown Alps/Buckling spring
- DT Pro Member: 0084
I'm using an Ersa Multitip C25 with 25W and it does the job just fine. I soldered my FaceU with it, a Soarer's Controller and some other small stuff. Desoldering also works with a simple solder pump.
- HzFaq
- Main keyboard: Phantom
- Main mouse: CST L-Trac
- Favorite switch: MX Clears
I have an Antex iron on a wire that I think I paid about £20 for about 2 years ago...it might even have come with an extra tip thinking about it. In total I've built about 3 or 4 customs and de-soldered something like 10 boards with it with no issues, its a great little iron, I'd definately go Antex again. I would like a station at some point, but until this goes wrong I can't really justify replacing it.
- ShivaYash
Thanks. What wattage is your iron?HzFaq wrote:I have an Antex iron on a wire that I think I paid about £20 for about 2 years ago...it might even have come with an extra tip thinking about it. In total I've built about 3 or 4 customs and de-soldered something like 10 boards with it with no issues, its a great little iron, I'd definately go Antex again. I would like a station at some point, but until this goes wrong I can't really justify replacing it.
- HzFaq
Just dug through some emails and found the invoice, it was this one.
http://www.amazon.co.uk/Antex-Xs25-230v ... =antex+25w
- DanielT
I like that Antex, I was on the look for something a little better than my CFH, the CFH soldering tips are not so good, I changed around 3-4 ( desoldered 3 boards, soldered 4 and some other small jobs).
And the price tag is decent.
- Hypersphere
- Main mouse: Logitech G403
- DT Pro Member: 0038
On the US side of the pond, Weller seems to be a good brand. They do a soldering station with thermal control for a reasonable price. Don't know if they are available in the UK.
- Khers
- Main keyboard: LZ CLSh
- DT Pro Member: 0087
I was thinking of getting that one (the Weller WHS40) since I knew Weller was a well renowned brand. When reading into it though, it seems like they merely put their name on something and that it is not nearly the quality you get if you buy the "real" stuff. In the end I went for a no name 40W soldering station instead. That one has served me well.
- matt3o
- -[°_°]-
- Main keyboard: WhiteFox
- Main mouse: Anywhere MX
- DT Pro Member: 0030
I have this http://www.amazon.co.uk/PROFESSIONAL-DI ... ng+station
it's a shit, but it works. Good bang for the buck (you can easily find it on farnell, mouser and on all amazon websites)
- Hypersphere
I got the WES51. I have only done one small job with it, but so far it has worked well.Khers wrote: I was thinking of getting that one (the Weller WHS40) since I knew Weller was a well renowned brand. When reading into it though, it seems like they merely put their name on something and that it is not nearly the quality you get if you buy the "real" stuff. In the end I went for a no name 40W soldering station instead. That one has served me well.
nice one , looks good
get yourself a nice flat tip for it the pointy ones most irons come with are useless. I don't even know what you would want to use a pointy tip for, i think its something you are not supposed to ask.
- Hypersphere
I use Kester rosin-core solder:
http://www.amazon.com/Kester-Rosin-Core ... B00068IJPO
Despite all the dire warnings about Pb-containing materials, I prefer Pb-alloy solder.
Fine SMD work usually... but definitely not using the ones that the cheap irons come with
- Touch_It
- Main keyboard: Unicomp Classic USB 103 key (work) IBM F 4704 107
- Main mouse: Logitech g502 Proteus Core
- Favorite switch: Buckling spring (yet to try Beam Spring)
I bought a $5.00 soldering iron from walmart lol!. My wife told her uncle that I needed one and was convinced i needed one asap when we were at walmart. I've soldered 3 times and I melted straight through the end of the tip. I suppose I should at least invest in a semi-decent tip as I need to desolder and solder in the controller on my 4704 and will likely be transplanting 104 switches. I know cheap isn't the way to go, but does anyone have any experience with buying tips at radio shack?
