After picking up the only usable model m from the local craigslist posted within the last 2 years I found this guy on my doorstep. See this keyboard (my first model m) was a coffee soaked one from ebay that was missing key-caps and had an ibm remote desktop cable. After typing on it for about a month its rivets began to pop like crazy. I dissembled the keyboard and sent the barrel with the bottom casing for the peeling label to be re-adhered, the internal label preserved, and the screw mod performed by none other than phosphorglow. When I got it back I slapped all the cleaned key-caps back on and here is the result:
All thats left to do is procure the correct ctrll and alt keys for the right side and screw in those hex screws
