Trying to steal the spotlight from Corsair?
Source: http://hexus.net/tv/show/2014/06/Rosewi ... nd_chassis
(keyboard mentioned at about 1:55)
I can't even tell if this is a Cherry MX keyboard, but it looks like it...
Rosewill shows off "RGB" backlit keyboard
- Nuum
- Main keyboard: KBD8X Mk I (60g Clears), Phantom (Nixdorf Blacks)
- Main mouse: Corsair M65 PRO RGB
- Favorite switch: 60g MX Clears/Brown Alps/Buckling spring
- DT Pro Member: 0084
The keyboard should use Kailh switches, similar to other RGB boards like the Tesoro Lobera Supreme. At least the folks over at geekhack say so. Also you can apparently just change the color of all keys together not on individual keys.
- scottc
Aha, that's it. Weird. That must be why they didn't elaborate on what type of switches it has. Thanks for the info!
- Grendel
- Main keyboard: CM Storm Quickfire XT MX Green
- Main mouse: Logitech G9
- Favorite switch: MX Ghost Blue
The NewEgg video is pretty open about it, the guy even spells Kailh
For $100 not a bad board IMHO, I'll check out what makes it tick in a little while...
