This keyboard...is ridiculous. If it weren't for the Univac for stealing it's thunder, it would have been my discovery of the year.
Teletype Capacitive Magnetic Rocker Switches.
It's Clicky, Capacitive, Magnets, Spring-loaded mounting mechanism, Spring loaded case pieces, and something I've never seen before. A double clicker.
An for you keycap fetishists, an Enter key, with an integrated steel plate and stem
One of the 4 spring-loaded levers.
The stand-alone keyboard base, the other base can be seen here: http://www.baudot.net/teletype/M40.htm
You can see the top cover spring-loaded lever in this pic, it's on the left (mat silver/grey).
This is where the lever hooks into.
The lever, spring is on the other side of the plate.
Key switch covers, the switches are there, but the keycaps do not allow for you to actuate the switches.
This case is SOLID. And heavy.
Spring for the top cover lever.
Volume control?
Spacers, these are a bitch to get out (the switches overlap a ridge, so you must get the switches out first).
Not sure, but probably a piezo buzzer.
Yep, that bronze looking thing is another spring for the spacebar
LED module.
Magnets hanging off the spacebar
So, there are 4 types of switches. White stems, normal. Orange stems, normal with floating LED (I did not open one because I would have to destroy the slider, but the internals should be very similar to the green). Black stems, locking switches. Green stems, double clickers.
I did not take out all the switch pieces due to the very fine piece of wire soldered into the switch...but there is nothing hidden from the pictures, so you are not missing anything
White Stem, normal switch. The click, is the slapping of the electrode (cathode or anode...one of the two
Orange Stem, LED switch.
Black Stem. Locking Switch. Yep, that's a magnet holding the locking wire in place
Green Stem. Double Clicker
The press. Depressed.
Level 1. Notice the movement of one of the electrodes.
Level 2. Notice the movement of the other electrode.
Video Full Album
http://www.flickr.com/photos/triplehaat ... 829504416/
Patents
https://www.google.com/patents/US3671822
https://www.google.com/patents/US3886543
https://www.google.com/patents/US3931610
https://www.google.com/patents/US3916090
