IC/Discussion on beige set
- matt3o
- -[°_°]-
- Main keyboard: WhiteFox
- Main mouse: Anywhere MX
- DT Pro Member: 0030
Okay after the extremely successful DSA Retro GB I'm considering a beige two tones set (yeah I know I'm the retro-man).
I asked some quotes and currently I'm torn between the following options. I'd like to know your opinion.
1) DSA PBT Dye-Sub from SP
2) SA ABS Double shot from SP (having all the missing keys done), basically a Realforce Hi-Pro clone
3) Standard Cherry Replica from GMK
Please note that all options would include 5-6 EU languages.
Option 1 is the one I like the most since we wouldn't have MOQ, we wouldn't have to build expensive tooling and ISO keys wouldn't be an issue due to dye-sub. Also PBT is always tempting, unfortunately spacebar will be ABS of course.
Option 2 is tempting but we probably miss tooling for at least the 2.75 shift, making the GB starting from 4500 USD.
Option 3 is also nice but of course we have to meet the 400 MOQ of GMK. I think we could hit that for ANSI but would be hard to do that much for ISO kits. I asked them if they could lower the MOQ for the ISO kit but I don't think that is going to happen.
What's your though?
What's your though?
- matt3o
- -[°_°]-
because it's easier to have all languages printed... and because of PBTGilgam wrote:DSA PBT Dye sub (why not double shot ? )
SA if FR is included.
- 7bit
- Favorite switch: MX Lock
- DT Pro Member: 0001
SA-family.matt3o wrote: 1) DSA PBT Dye-Sub from SP
Legends are all there (except for SHIFT they must invent the FT-ligature).
If they want $4500 for the tools for 2.75 units shift key, they raised their prices quite a bit. We had to pay $3500 for each space bar.
Nevertheless, it should be doable.
Sell 450 kits and add 7.69 EUR to each kit and people get a 2.75 units SHIFT key.
If you are clever you can add a right SHIFT in Round 4 SPHBLUE.
btw. how is their printing ? can you ask them to send you the files, so you can check where we can improve them?matt3o wrote:because it's easier to have all languages printed... and because of PBTGilgam wrote:DSA PBT Dye sub (why not double shot ? )
SHIF T
- matt3o
- -[°_°]-
I seem to recall they said $4500, but it could be $3500.7bit wrote: SA-family.
450 kits would be a hell of a result. Don't know if it's doable.
dye sub is a printing process, legends are not molded. We could have any typeface, at any size, at any kerning we want.mintberryminuscrunch wrote:btw. how is their printing ? can you ask them to send you the files, so you can check where we can improve them?matt3o wrote:because it's easier to have all languages printed... and because of PBTGilgam wrote:DSA PBT Dye sub (why not double shot ? )
SHIF T
That's why I'm saying we should have them checked before they start printing, or will you create your own?matt3o wrote:...
- matt3o
- -[°_°]-
this! (sorry didn't mention it before)mintberryminuscrunch wrote:That's why I'm saying we should have them checked before they start printing, or will you create your own?matt3o wrote:...
- dirge
Option 4
GMK doubleshot version of 10th anniversary
With optional vintage cherry function row (before I go insane and killpeople)
really tho, if it ends up being GMK matty, just DO that function row please. maybe even the nav cluster and arrow keys too...
I was just reading the discussion on this at GH this afternoon, and wondered when we would hear about it again. Very tasty range of choices, but the pain is in having to pick just one!
Option 2 is my favourite. Option 1 is also very strong. Option 3, not for me.
SA really does draw me right in. I absolutely do want a little HiPro of my own design! That profile does introduce the complexity of row dependency between keys, though. With DSA you can just go wild, and I did with my backspace in particular. SA, well, I'd have to play it safer. Could go blanks, of course, but double-shot is so hard to turn down when it's on the table.
PBT dyesub DSA is also highly interesting. Its pros and cons are complementary to SA in DS ABS.
The colours matter quite a bit too, of course. I'd like to know what retro machine in particular we're going for. In fact: how about a different font this time, too? There's nothing as authentic for the old school look, and as adaptable, as Helvetica. If it's retro enough for the Model F:
Note: Helvetica. Not Arial. The G is how you tell.
Changing font means we could kiss SHIF T goodbye forever. Helvetica has its kerning aced.
- matt3o
- -[°_°]-
you really like that color combo, don't you?dirge wrote:With optional vintage cherry function row (before I go insane and killpeople)
Please note that SA would be all on ROW3, so no key profiles anyway.
Music to my ears!matt3o wrote:Please note that SA would be all on ROW3, so no key profiles anyway.
Are you sure you want to command another intercontinental GB, though, Matteo? I hear that running a few too many of those is a sure way to end up a little … well … 7bit.
- 7bit
Yes, me too!matt3o wrote:...
Why all in row 3, BTW?matt3o wrote:Please note that SA would be all on ROW3, so no key profiles anyway.
- matt3o
- -[°_°]-
yes going through GMK would be better, but we would be locked on DCS layout.Muirium wrote:Are you sure you want to command another intercontinental GB, though, Matteo? I hear that running a few too many of those is a sure way to end up a little … well … 7bit.
I thought it would be better, no? You'd prefer a profiled layout?7bit wrote:Why all in row 3, BTW?matt3o wrote:Please note that SA would be all on ROW3, so no key profiles anyway.
Profiled is better, in the abstract, but causes trouble for layout tinkerers like me and surely for the organiser, too. A whole other dimension for people to request options on and squabble over.
SA taking a fixed-profile page out of DSA's book is fine by me.
- matt3o
- -[°_°]-
yes, if we go PBT, blanks will be added for sure.
Actually I'd like to keep this inside EU, but I don't think GMK will be feasible.
- rindorbrot
- Main keyboard: Phantom, GON NerD 2.0 TKL
- Main mouse: Zowie ZA11
- Favorite switch: MX Ergo-Clear, Nixdorf Soft-Touch
- DT Pro Member: 0029
Is SP even able to make a PBT ISO Enter? AFAIK at least for DCS they say they can't.
- matt3o
- -[°_°]-
I'll double check that. thanks for pointing that out, but they didn't raise an alert when I asked.rindorbrot wrote:Is SP even able to make a PBT ISO Enter? AFAIK at least for DCS they say they can't.
I'd like to have UK, DE, SE, IT, FR, ESzulios wrote:If you consider including FR, I'd love option 1.
- guilleguillaume
- Main keyboard: Kmac Mini
- Main mouse: Razer Abyssus 2014
- Favorite switch: Topre
I would choose the first option over the second one but is GMK able to produce the original Cherry spherical keys?
Can't find the other pictures taken by Sixty.Two of the microphones we use at work use these keys but being lasered engraved keys.
I love Dirge's function layout with yellow keys but I hate the 10th anniversary colour scheme
- matt3o
- -[°_°]-
GMK is unable to produce full spherical-top sets. If it's GMK it's standard layout.
- douchecanoe
- Main keyboard: Filco Majestouch 2
- Main mouse: Logitech G500
I would probably be in for this one, provided you do ANSI and open it up for North America. Kinda pissed I missed the Retro GB, but this should look nice too, especially if I do a sleeper build for my next PC
This is getting me hot, damnguilleguillaume wrote:![]()
- Favorite switch: MX Red
If you do end up going with GMK, maybe you could flip it so it stands out from all the 'easy' to find vintage Cherry sets out there...
I would love something like that for more standard modern layout. Also if you didn't want to deal with North America, I would be willing to help out.
- vivalarevolución
- formerly prdlm2009
- Main keyboard: IBM Beam spring
- Main mouse: Kangaroo
- Favorite switch: beam spring
- DT Pro Member: 0097
As long as we have MALTRON layout in SA profile, I am all in.
Ok, I know that is a long shot, but make it happen.
