It just seems to fit mine, I need to spend more time understanding why and if it would fit all phantoms, I've got three but don't think the 7bit special will squeeze in there lol.
So I was expecting that the lack of rear standoffs would mean that the rear of the board would need lifting and that some vertical movement would be present when you turned the case upside down. That isn't the case after fitting mine. Whether its the USB cable or not, I'm not sure. I'll check tonight and take photos.
There is some lateral movement, again due to no screws into standoffs. However it's quite difficult to get the phantom to move. Must be due to the friction and how tight the fit is. I don't see it as much of a problem and during normal use I wouldn't expect it to happen.
The case has a few scratches and tiny dings here and there, this may irritate some people.
The case over its total length is maybe out by a mm or so, the escape is aligned to the right hand side of its opening. The arrow cluster is aligned to the left hand side of its cutout. Again not by much at all, you'd need to really look to see it.
Now I just need to get a metal shop to cut me two small squares to act as winkey blockers like the modded poker case above and I'll be very happy! (oh and anodize the damn case... I was going to go for a light gray)
^ that's always what I've been aiming for with the phantom
