EDIT: Most preferably within eu as had horrible experiences posting from us to uk.
EDIT2: My keyboard is ANSI
Thanks!
DAMN YOUDeathAdder wrote:Was supposed to... They had issues with a company backing off
Oh, just unmade your day, sry :/
are you sure? so it's only the one with blue switches and white layout? you mean new models right?damorgue wrote:If you want PBT ISO, there is only one source that I have ever found, the G80-3000LSCXX-0.
It is the only board EVER to be made, with ISO PBT caps and subtle or no legends. (OP asked for blanks.) It comes in black or white.cinch wrote:are you sure? so it's only the one with blue switches and white layout? you mean new models right?damorgue wrote:If you want PBT ISO, there is only one source that I have ever found, the G80-3000LSCXX-0.
like i have one with clear switches and black layout, but pretty sure it's ABS.
ah ok, when you said XX you meant XXdamorgue wrote:It is the only board EVER to be made, with ISO PBT caps and subtle or no legends. (OP asked for blanks.) It comes in black or white.
for those searching this model number. i can confirm the G80-3000LSMDE has ISO PBT (german).damorgue wrote:If you want PBT ISO, there is only one source that I have ever found, the G80-3000LSCXX-0.
