I love them both :0
It is ... searching for words ... everything seems possible with this thing!!! Plus you can make it quick and easy. Very intuitive, everythings snappy and very good keys/encoders (the keys feel similar to apple laptop keys, certainly better than the usual synth buttons). It's heavy, massive almost. Long battery life, I've tested it by leaving the radio on with 3 FX (EQ, Punch and Drive): it lasted 19h. It never get's hot. Sampling from radio or via the mic is done in a sec and you can instantly play the sample on the keyboard. The new OS adds a ChopLifter game (launchable via secret (but easy to find) key-combo), a new Drum Synth, MIDI sync and MIDI controllable "LFO's" as well (you can use your DAW or hardware sequencer to modulate the synth/envelope/fx params via those). And there is more to come in future OS releases! Happy.modulor wrote:Good choices! I just got a Poker myself...how do you like the OP-1?
