can anyone tell me how to post a table on deskthority?
wcass
01 Jul 2012, 00:20
the post subject says it all.
GH1391401
01 Jul 2012, 06:44
Row1    Row1    Row1    Row1
Row2    Row2    Row2    Row2
Row3    Row3    Row3    Row3
#terribleAnswer
Maarten
01 Jul 2012, 11:16
Table code seems disabled, ask the admins.
off
01 Jul 2012, 12:07
In the wiki you can; but the way to input one there is even worse than the example posted.. by gw?
Topre Enthusiast
01 Jul 2012, 12:32
It's not difficult to make the tables on mediawiki - just time consuming. It's a lot easier to use notepad++ or something and then just paste it all in.
I was also looking for how to create tables on the forum but it looks like webwit might need to add some plugins or something. I ended up just taking a screenshot of excel and putting it on imgur lol
RC-1140
01 Jul 2012, 16:42
also tables on MediaWiki are somewhat similar to LaTeX, so LaTeX users shouldn't have any trouble with it.
ripster
01 Jul 2012, 16:43
I use the excel plugin.
Works great!
http://deskthority.net/w/index.php?titl ... oldid=7012
Wiki tables using Excell Plugin.PNG (12.66 KiB) Viewed 3684 times
http://excel2wiki.net/index.php
dirge
01 Jul 2012, 16:51
off
01 Jul 2012, 17:05
RC-1140 wrote:also tables on MediaWiki are somewhat similar to LaTeX, so LaTeX users shouldn't have any trouble with it.
002 wrote:It's not difficult to make the tables on mediawiki - just time consuming.
Well actually noone but Ripster (already past that point now) should have any technical challenge with those tables, it's just annoyingly crappy manual work.
ripster
01 Jul 2012, 17:46
Please table the Ripster baiting. I can only post once an hour so can't really waste posts on small talk.
or puns........
01 Jul 2012, 17:51
ripster wrote:Please table the Ripster baiting. I can only post once an hour so can't really waste posts on small talk.
or puns........
LOL!!!
:lol:
BTW: tables are not really important but to be able to select a fixed width font would be great!
01 Jul 2012, 18:24
Installed a table mod (see button on editor). Needs polish.
01 Jul 2012, 18:32
webwit wrote:Installed a table mod (see button on editor). Needs polish.
Nevermind.
:oops:
01 Jul 2012, 18:33
7bit wrote:BTW: tables are not really important but to be able to select a fixed width font would be great!
It should work now.
It should [monospace]work[/monospace] now.
01 Jul 2012, 18:33
It should work now.
I love you!!!!!
wcass
02 Jul 2012, 03:13
thank you ripster and webwit.
ripster
02 Jul 2012, 03:39
You are welcome.
Damn, now I can't post for an hour.
Return to “Off-topic”
