Findecanor wrote: 08 Jan 2023, 16:53
What is "MX form"? Form factor of the switch? MX keycaps? Compatibility with PCBs? ...with plates?
All of the above.
Muirium wrote: 08 Jan 2023, 16:42
Remember that silo modules aren’t switches. As I recall, they’re a tactile mechanism that sits on top of an external sensor. Just like buckling spring! But not at all like MX.
To cram a buckling spring and a sense mechanism (even a
reed switch) into a dinky little MX sized module: now there’s a technical challenge.
So, if possible it would actually be a module sitting on top of a sensor. I am still pretty new to a lot of keyboard hardware, but if it went that route, that would also affect the types of PCBs it could be used with? It couldn't be compatible with just any pcb you could just buy?
It would need IBM/Unicomp keycaps and still be tall. Even taller with MX keycap-compatibility.
The biggest benefit IMHO would be for ergo keyboards for which there are PCBs with many different layouts.
Hey, I wouldn't mind that. There were some pics with the Keystone tactile switches where, I swear, they look a bit wider and taller than traditional MX switches. Which would suite me just fine!
inmbolmie wrote: 08 Jan 2023, 13:20
In the case of Buckling Springs as I see it the key factor is low complexity. That is you just have the key, barrel, spring and flipper. Putting that into a MX package will involve more parts and complexity (and possibly losing dust resistance) and I don't see it worth the hassle.
What I was thinking was something that looked just like an MX on the outside with the same housing and the same slider (think Silos), but inside the slider has a forked stem where the mini BS-spring could be positioned. It would work just like with a BS and an IBM/Unicomp keycap mechanism on the inside. MX on the outside, but buckling spring on the inside (miniaturized of course.
