- Externally: the keyboard is in perfect external condition, the top plastic case doesn't have scratches or parts where the paint is missing.
- Internally: the switches feel very good, smooth, and aren't dirty. There isn't any corrosion and all the previous galvanization is still intact. In my opinion, it doesn't need a foam replacement, there isn't a lot of wobble. But if you want I can ship some EVA 2 mm foam.
- Functionality: I tested every key with the controller and they all work. The layout might be a little hard to get used to but with a good setup (the controller uses QMK) you can use the keyboard every day with no problems.
Shipping worldwide, EU is preferred. Also listed on other websites.
27/03/2022 - SOLD
