[IC] Wave 88 F13 TKL by Oasis Industry
Oasis Industry
14 Feb 2022, 08:04
Hi everyone. Here is Oasis Industry.
Good news! We are introducing our first keyboard Wave 88 today.
Black Case + Chrome Weight
1 下午2.32.21.jpeg (220.3 KiB) Viewed 13636 times
Please Check Introduction
Our first customized keyboard WAVE 88 originates from a lame joke,
-” How can you tell if the ocean is friendly or not?”
-” Because it WAVES!”
As our first product, WAVE 88 should be friendly as the ocean, and we would always express our warmest welcome to all lovers of the customized keyboard to use our products.
In the oasis in the desert environment, you can hardly find the ocean or see the wave. However, we hope that we could have the ocean in our Oasis, which has multiple meanings:  Creativity, Freedom and Improvement.
Typing experience and Sound signature.
The structure of WAVE 88 is PCB Gasket Mount and supports both plateless(Primary) & with the plate to provide customers with different choices.
Our PCB is Designed and powered by Owlab.
The way of fixing is to put rubber socks on both ends of the leaf spring.
Default Specifications:
  • F13 TKL
  • 6061 Full aluminum
  • PCB Gasket Mount [support plateless(primary) or with plate]
  • 7.5° Typing Angle
  • Type-C
  • USB-C daughterboard
  • WK / WKL
  • Solder PCB(support plateless) / Hot-swap PCB(with plate + flex cut design)
  • Two different PCB kits offer different typing experiences & typing sounds
  • QMK/VIA/Vial Supported
  • ANSI & ISO Layout (7U spacebar for more aesthetics)
  • Owlab 80% stabilizers
  • Poron foams kit
Anodized Case Color: Black, Blue, Red, Dark Green, Silver
Electrophoresis Case Color: White
Weight Color: Gold, Silver, Sandblasted, Chrome The front badge & the weight are of the same color
Estimated GB time: mid-March 2022
Estimated GB price: around $400, 70% probably under $400.
We are working hard to handle all details, only hope it can let you have a more good experience. Please fill in below IC form with your idea and make this keyboard better and better.
Please fill in our IC form at: https://forms.gle/JYd14NKG6QU2Qfnw8
We recommend you join Oasis Industry Discord for more details: https://discord.com/invite/jzNuph5AJV
We will release more updates in the coming weeks, including streamers' typing tests & building videos.
Feel free to comment & put forward your suggestions here.
Thank you for your support!
Here are three typing tests:
