IBM 5291 Model F "Bigfoot" keyboard review (capacitive buckling springs)
18 Jan 2020, 11:37
Time to tackle one of the more overlooked members of the Model F family; the 5291 "Bigfoot"! Hope you enjoy the video :) .
sharktastica
18 Jan 2020, 12:00
Great video as always!
I can confirm that once converted, it serves us well! It's just a super cool keyboard to grace your desk with! There's a lot more wires involved than the usual Soarer's since the thing has to act as the keyboard's processor, but Soarer did most of the work for us (pinout, firmware, and template .sc to use) before they left us. The only issue I've had with it is that getting debouncing right took me a about a week of tweaking and spending a fair bit of time trying to use it normally whilst looking out for any repeated characters or dead keys.
adamcobabe
18 Jan 2020, 14:13
Nice review. As soon as I find a nice XT cable, I'm going to swap the Lexmark-ish assembly with the NOS F XT assembly I got from Redmaus, which feels very crisp.
manisteinn
18 Jan 2020, 16:18
I got three of these a couple of years ago and made a controller board for them, it just slides on the pin header.
(Click for larger)
I'd be happy to send you one for free, I appreciate your reviews!
It was a very rushed addition to a PCB order and no rushed project is complete without an annoying error: strobe/data are swapped. It's a trivial change in Soarers configuration file though.
Now there's also a QMK project for it, I haven't tried that.
I panelized this and the xwhatsit solenoid boards, so I got 60/80pcs respectively for a total of $10 :D
If anyone wants bare boards feel free to PM, I can send a couple of each for the cost of shipping (~3€).
BOM (I'll publish the full project on github "soon")
Ref	Value	Footprint
C1	18p	Capacitor_SMD:C_0603_1608Metric_Pad1.05x0.95mm_HandSolder
C2	18p	Capacitor_SMD:C_0603_1608Metric_Pad1.05x0.95mm_HandSolder
C3	1u	Capacitor_SMD:C_0603_1608Metric_Pad1.05x0.95mm_HandSolder
C4	0.1u	Capacitor_SMD:C_0603_1608Metric_Pad1.05x0.95mm_HandSolder
C5	0.1u	Capacitor_SMD:C_0603_1608Metric_Pad1.05x0.95mm_HandSolder
C6	0.1u	Capacitor_SMD:C_0603_1608Metric_Pad1.05x0.95mm_HandSolder
C7	0.1u	Capacitor_SMD:C_0603_1608Metric_Pad1.05x0.95mm_HandSolder
C8	0.1u	Capacitor_SMD:C_0603_1608Metric_Pad1.05x0.95mm_HandSolder
F1	Polyfuse	Fuse:Fuse_0805_2012Metric_Pad1.15x1.40mm_HandSolder
J1	Keyboard	model-f-5291-footprints:Harwin-M20-7811045
R3	22	Resistor_SMD:R_0603_1608Metric_Pad1.05x0.95mm_HandSolder
R4	22	Resistor_SMD:R_0603_1608Metric_Pad1.05x0.95mm_HandSolder
R5	1K	Resistor_SMD:R_0603_1608Metric_Pad1.05x0.95mm_HandSolder
U1	ATmega32U4-AU	Package_QFP:TQFP-44_10x10mm_P0.8mm
Y1	Crystal_GND24	Crystal:Crystal_SMD_3225-4Pin_3.2x2.5mm
USB-C
J2	USB_C_Receptacle	model-f-5291-footprints:USB_TypeC_U31F-24SNA0201
L1	DLW21SN900SQ2L	model-f-5291-footprints:DLW21
R1	5.1K	Resistor_SMD:R_0603_1608Metric_Pad1.05x0.95mm_HandSolder
R2	5.1K	Resistor_SMD:R_0603_1608Metric_Pad1.05x0.95mm_HandSolder
R6	330	Resistor_SMD:R_0603_1608Metric_Pad1.05x0.95mm_HandSolder
C9	0.1u	Capacitor_SMD:C_0603_1608Metric_Pad1.05x0.95mm_HandSolder
etc
J3	USB	Connector_PinHeader_2.54mm:PinHeader_1x04_P2.54mm_Vertical
JP1	Jumper_NO_Small	Connector_PinHeader_2.54mm:PinHeader_1x02_P2.54mm_Vertical
MH1	MountingHole_Pad	MountingHole:MountingHole_2.2mm_M2_Pad_Via
MH2	MountingHole_Pad	MountingHole:MountingHole_2.2mm_M2_Pad_Via
SW1	SW_SPST	model-f-5291-footprints:MX_Matias_KailhLP_NoSilk
Bass
19 Jan 2020, 11:09
Have you tried mounting some caps from your other F's and seeing if that makes a difference in smoothness? I've long suspected that my 1386965 Unsaver was actually Lexmark made and have found that the stock caps it came with are scratchier than other F caps I have tried mounted on the same keyboard (regardless of whether or not they are one or two-piece) . It's especially noticeable on off-center key presses. Model M and Unicomp caps also reproduce this scratchiness in my testing. I have heard other people throw around theories that the newer caps are not "optimized" as well for Model F barrels, so to speak.
As you said in your review, they still feel great to type on and I don't really notice it when I am typing fast enough, but it would definitely be nice if I could find an F122 to harvest some 2-piece caps from and swap the bottom parts out. Which reminds me....
SneakyRobb
THINK
19 Jan 2020, 22:55
Bass wrote: 19 Jan 2020, 11:09 Have you tried mounting some caps from your other F's and seeing if that makes a difference in smoothness? I've long suspected that my 1386965 Unsaver was actually Lexmark made and have found that the stock caps it came with are scratchier than other F caps I have tried mounted on the same keyboard (regardless of whether or not they are one or two-piece) . It's especially noticeable on off-center key presses. Model M and Unicomp caps also reproduce this scratchiness in my testing. I have heard other people throw around theories that the newer caps are not "optimized" as well for Model F barrels, so to speak.
Hi, I will throw some theories. I don't have evidence but I personally consider Model M and Model F keycaps to be different key caps. They have the same dimensions, but they are not the same. Something about Model M keycaps is rougher when used in the Model F barrels.
I am convinced something about the formulation of the plastic barrel plate of the Model M allowed IBM to remove some kind of lubricating coating/additive from the keycaps. This doesn't mean Model M keycaps are bad, but IMHO the plastic is designed to work with the Model M barrel plate.
SneakyRobb
THINK
19 Jan 2020, 23:05
Great video. This was the first Model F that I got. I didn't know what it was and how it was different from the XT. I just read that Model M was a cheaper Model F, so I got a Model F. They look so alike to the untrained eye!. I ordered one and just couldn't get it to work. Soarer actually sent me some information and messaged with me about how to get it to work properly which was really cool and is a fond memory.
It is kind of strange to try to reverse think the reason for the extreme bezel size. So often what seems like a reasonable design choice relies on considerations so far from what we can imagine.
Elrick
22 Jan 2020, 02:09
SneakyRobb wrote: 19 Jan 2020, 23:05 It is kind of strange to try to reverse think the reason for the extreme bezel size. So often what seems like a reasonable design choice relies on considerations so far from what we can imagine.
The huge Bezel size is what attracts all those that appreciate the importance of this design.
Having something around the switches to rest your hands on whilst typing huge scripts of code or writing a new book. Also using the surround to stick notes and stickers help to customize your own work space, which was this keyboard and the PC it was attached to all those years ago.
Love to have a resurrection of this design but using the standard ANSI layout. That would be the end-game of all keyboards if it was ever released.
You couldn't find another in that unique size :D .
Darkshado
22 Jan 2020, 07:05
No reason you couldn't fit something like an XTant assembly in this case... viewtopic.php?f=7&t=3047&start=300
SneakyRobb
THINK
22 Jan 2020, 17:41
Darkshado wrote: 22 Jan 2020, 07:05 No reason you couldn't fit something like an XTant assembly in this case... viewtopic.php?f=7&t=3047&start=300
XTravagant idea
Return to “Reviews”
