Not much on the labels, no manufacture date or anything.
And as you can see, someone really used the heck out of this thing! They must have had long nails too to do this sort of damage to the spacebar.
Close up on the spacebar. Yikes.
Some M9s, this stem isn't compatible with newer MX caps, but later stems are. Except for the oldest examples of these caps, they are compatible with the later stems. I do not know who made these caps (Cherry maybe?) but they did a fantastic job and the suspicion that the Miniprint had these caps was a big factor on getting it.
Closeup on some more nail damage.
Comparing the caps on this with the caps from another old Cherry board. Definitely the same manufacturer.
A very workable numpad could be made from these if one so desired. Only thing missing is the *
These are PCB mount, except for the spacebar, which uses a plate held to the PCB by 2 tall rivets to hold in the stabilizers. Not the worst design I suppose.
removed from the Miniprint like this the thing looks super cool.
pics of non-keyboard internals:
