Looking for a replacement keycap set for a G80 1800 (ISO , winkey bottom row)
Something like them cheap china caps .
Would this work do you think ?
https://www.aliexpress.com/item/3290878 ... b201603_52
G80 1800 replacement key-cap set
- DT Pro Member: 0011
That EnjoyPBT base set would have fit... I think. The only question is if the included 6u space bar had an off-centre stem or not. (The EnjoyPBT/Gateron sets I have got do, and would fit)
