My build log here: https://imgur.com/gallery/87LfDVI
Parts and Tools list: https://imgur.com/gallery/vhRCIH2
Fake click sound from black-small-speaker on the left of Teensy: https://imgur.com/a/ZlY8Zfd
Keycap on: https://imgur.com/gallery/MKLQ6S2
What about a solenoid with a clicker?snacksthecat wrote: 02 Sep 2019, 22:20 I love the buzzer as well. Just used a similar one in one of my projects. I wish it made a "click" noise though. Does such a component exist?
That's quite informative, with good pictures. Good stuff!
It does. And the Elite-C has one too, but in pin order in about the same position.Muirium wrote: 03 Sep 2019, 18:50 Especially if I’m right in thinking it has a hand solderable USB breakout, so you don’t have to hack up awful bulky cables.
There are extension cables/adaptors with sockets for panel-mounting, but all I've found so far have been "30 cm" long, which is just a too long for a keyboard.Muirium wrote: 03 Sep 2019, 18:50 Routing USB cables is my least favourite step in hand wired keyboard building, if you didn’t guess already! Loathe that bit. There’s got to be a better way.
There is currently a large backlog of orders. Click here to see the entire list of orders - new ones are placed at the end unless it's being merged with an existing one.
https://www.reddit.com/r/MechanicalKeyb ... ingjunior/PlacaFromHell wrote: 03 Sep 2019, 02:46What about a solenoid with a clicker?snacksthecat wrote: 02 Sep 2019, 22:20 I love the buzzer as well. Just used a similar one in one of my projects. I wish it made a "click" noise though. Does such a component exist?
Keycapsss has the 2u Ameoba board. (Thanks, Bendim!)Findecanor wrote: 04 Sep 2019, 01:58 BTW, there is a 2u Ameoba board (OshPark) with footprint for 2u PCB-mounted stabilisers, so that you could stabilise that Space bar.
I have seen the 1u Amoeba at other places, but not the 2u other than on OshPark.
