Three days ago I got the idea of design my own switch, considering what I think may result in an S-tier switch. I came up with this thing, the model was ended today:
PFH magnetic collar switch
Naked view
As you can see the switch is a bit too complex and somehow over engineered. I'll try to explain part by part how this thing operates, clicks and all the important stuff.
In summary, what is this thing? This is an SPST reed switch switch operated by a magnetic clicker, actuating at 2mm with an overrun of 1.5mm.
Now that we have polished the general concept, we go by pieces:
Housing upper part: Maintains the switch closed using screws on the top. Not much to say about this part.
Housing middle part: Similar to the upper part, not much to say. It has a piece of plastic in the middle to retain the orange piece called ferromagnetic plate and also prevents the slider from having a too large overtravel. Because of this plastic neck the housing is divided in three parts.
Slider: Standard MX cross mount with a flat H shapped base in order to have a very high stability and avoid wobble (this shape may cause some friction problems). The spring under it is designed to be screwed/moulded inside the plastic piece, but this may not be necessary. It has an extension inside the spring to push the magnetic plate after the 2mm pretravel.
Ferromagnetic plate: A piece of metal used to attract the magnetic plate, goes glued under the plastic collar of the middle part of the housing.
Magnetic plate: Two magnets moulded (or glued) in a plastic piece. The one with a ring shape is used as a clicker, resisting being separated from the ferromagnetic plate. The flat one is used to activate the reed switch. It has a sort of engraving to hold the spring in place.
Housing lower part: Holds in place the reed switch and has two plastic fingers to prevent the magnetic plate from hitting it. I still can't decide if the screws just "end" here or use them as a way to hold the switch to the PCB instead of a standard plate.
This thing isn't ended, obviously. Some measurements aren't the ideal ones and the concept is not even proven. I would like to be able to promise that one day they will see the physical version of this thing, but I don't think I can afford it, I just want to make a logistical contribution about how great the magnets can be. I will continue updating this thread if necessary.
