!!!!!!!Updates 20.05.2019 !!!!!!!!!
1. - We are thinking of making colors for Space Cadet, GMK Serik, Laser, Carbon (You can choose which color of coil and which straight end)
2. - We will most likely have new Avia connectors (we will also leave the old ones in R1)
3. Most likely we add our cases to USB from brass (colors will be Platinum Rose Gold and Polished Brass)...
Follow us in social networks and discord thanks
Watch me here:
Discord - https://discord.gg/6aDRytB
Instagram - https://www.instagram.com/santigo_customss/
FOTO - https://imgur.com/a/NXmHsaA
GH R1 - https://geekhack.org/index.php?topic=100009.0
Hello everyone
... And so we finished R1 on vintage cables .... We received a lot of positive feedback and suggestions .... The first thing I want to say is to everyone, thank you who entered the first round.
I will still have updates on the second round so watch me) BUT I CAN SAY EXACTLY WHAT WILL BE "PAUNDE WITH US" LASER cable ….
You motivate me even more to do something unusual.
And so what constitutes our cable.
We are doing it in Italy and wanted for a long time to repeat something like the OG cherry. But OG Chery for me were not flexible and can be said even as very tough…
I started testing the materials, it was a long road _) but I found what I wanted a GOOD thick cable with a good coil robot .... you can look at saw how it comes back without problems and does not stretch.
The size of my cable is Standard: L1 side keyboard connectors 20cm (8 inches)—--— Coil 30cm (12 inches) —--— L2 side PC connectors 1m ( 40 inches). Outer diameter: coils — 25mm (1 inches), cable — 6.5mm (0.25 inches).
But as I said above, we make them ourselves and can make what size you need….
After 1 GB, a lot of people write what they would like to buy ... but since we produced only 70 of them, they bought out very quickly .. And I would like to do 2 round in the near future ...
the price of this cable will be 28 or 34 euros ... we will specify this later
I appreciate your every feedback and I will be glad if you can help me with this IC..
TEST COILS - GOOGLE FORM IC - https://docs.google.com/forms/d/1j1ry6H ... wGEoc/edit
Modify message
