It can be low cost.model.
I need this specific connection
I am not sure,Findecanor wrote: 09 Apr 2019, 22:18 You can't just go by the type of connector. There are quite a few different keyboard interfaces that use modular connectors, and 4P4C in particular (or is that a six-position connector?)
DEC LK201, Wyse and Ampex 220 are among those using 4P4C, and I a think all of them use proprietary pinout and protocol over the wire. And I'm sure that there are many more.
Thanks bro.Findecanor wrote: 10 Apr 2019, 13:28 All right! I searched around on the forum a bit for you. I found that elecplus in Texas might have a few Link MC5, at least back in September. She saves keyboards from electronics recyclers that she sells on, and she is quite respected around here.
It also looks like the same model as the Wyse-protocol version of the Wyse PCE. I've heard that it and Link MC5 should be compatible, but I have not (yet) found confirmation from someone who has actually tried it.
Good question... Sometimes the ends of a modular cable have the pins in reverse order, and according to Wikipedia even a handset cable could be in reverse order.
Findecanor wrote: 10 Apr 2019, 18:22Good question... Sometimes the ends of a modular cable have the pins in reverse order, and according to Wikipedia even a handset cable could be in reverse order.
In most modular cables, you should be able to see the colours of the individual cables inside the clear-plastic connectors if you look closely, to determine if that is the case.
Otherwise, making a modular cable yourself is pretty straightforward using a "crimping tool". (It should be possible even using a flat-head screwdriver...)
