Where should I look for 1.2mm plastic sheets to make an alps plate?
- BloodyKafir
- Main keyboard: AEK II with Lubed, Linearised, Undamped White Alps
- Main mouse: Razer Basilisk
- Favorite switch: Brown Alps, 62g Ergo Clears, lubed linears.
I am looking to do a top mount alps brown build, and need to find a 1.2mm POM/Delrin/PBT sheet to cut. Anyone know where I should look?
Fkazim
- Main keyboard: Modded IBM Model F AT
- Main mouse: Mionix Naos 8200
- Favorite switch: Capacitive Buckling Springs
Here's a link where you can buy the delrin PBT plastic the only thing is the thinnest size they have is 2mm hope that helps
https://www.ebay.co.uk/itm/ACETAL-Sheet ... IKfTPBz2Bw
- DT Pro Member: 0011
If you are laser-cutting then exact thickness is important. Most plastics are quite brittle and at 1.2 mm you would absolutely need a supporting PCB underneath, or if you hand-wire: use multiple sheets glued together or have a thicker plate machined with slots for the switches' snaps.
When scavenging Alps switches from an old keyboard, it is very easy to break the snaps by mistake because they are of very thin ABS and therefore brittle. If I hardware Alps, I think I would glue the switches to the plate in that case.
Delrin is a type of Acetal / POM. POM is not an approved material in all laser-cutting shops and while tougher than ABS it is still somewhat brittle and is too slick to take glue well. I think it would therefore be more feasible to get a larger thickness and have it machined. But if you are having it machined anyway, then a good type of aluminium might not be that far off in terms of cost: as it is the set-up work and machine time that typically cost the most.
I think that most laser-cutting shops and maker spaces should be able to provide you with acrylic sheet although 1.2mm thickness is more unusual. I think there are many suppliers and it varies a lot locally. I would check the phone book and phone around for shops first, and plastics suppliers later.
- swampangel
snacksthecat got a 1mm PETG sheet from Ponoko, if that's an option viewtopic.php?p=440556#p440556
