Nick.
help on model F
Metzu
- Main keyboard: ibm model M
- Favorite switch: spring
hi guys! i finally got my model F with Soarer's Converter,can anybody walkme trough on how to get the arrow keys back
same for f11 the keyboard feels very diffrent from my model f i been using for years now.
Nick.
Nick.
- Chyros
Eh, do you mean, how do you use the arrow keys on the numpad? You can toggle between numbers and arrows/nav commands with the Num Lock keyMetzu wrote: 13 Feb 2019, 08:55 hi guys! i finally got my model F with Soarer's Converter,can anybody walkme trough on how to get the arrow keys backsame for f11 the keyboard feels very diffrent from my model f i been using for years now.
Nick.
Metzu
exactly how do i programed it?AJM wrote: 13 Feb 2019, 10:08 And to get F11 and F12 you have to program a makro with the Soarer's converter software.
I put F11 and F12 onto F1 and F2 in combination with <ALT> or <CTRL>.
Metzu
thank you man!Chyros wrote: 13 Feb 2019, 09:27Eh, do you mean, how do you use the arrow keys on the numpad? You can toggle between numbers and arrows/nav commands with the Num Lock keyMetzu wrote: 13 Feb 2019, 08:55 hi guys! i finally got my model F with Soarer's Converter,can anybody walkme trough on how to get the arrow keys backsame for f11 the keyboard feels very diffrent from my model f i been using for years now.
Nick..
- AJM
- Main keyboard: Geonworks W1-AT
- Favorite switch: Lichicx Lucy
- DT Pro Member: 0231
This is a config file, that "corrects" the 2 ISO-specific keys, maps AltGr to the CapsLock key and assigns F11 and F12 to <CTRL> + <F1> and <CTRL> + <F2>:
# Soarer Converter's configuration for an IBM Model F XT keyboard.
remapblock
BACKSLASH EUROPE_2
BACK_QUOTE BACKSLASH
# AltGr.
CAPS_LOCK RALT
endblock
macroblock
macro F1 CTRL
PUSH_META CLEAR_META CTRL
DELAY 5
PRESS F11
POP_ALL_META
endmacro
macro F2 CTRL
DELAY 5
PRESS F12
POP_ALL_META
endmacro
endblock
