Buckling spring keyboards
Hey! does anybody have a buckling spring keyboard that they are willing to sell? I have a budget of about $100, but if you have a custom (do those even exist?) buckling spring keyboard I'm willing to spend more. Thanks!
- elecplus
- DT Pro Member: 0082
That is a rather broad request. Model M, M2, F? 62 to 122 keys is a broad range
Can you please be a little more specific?
Anything with dedicated function keys under 122 keys is good. also, whats an M2?
- ZedTheMan
- DT Pro Member: 0219
I'll sell you a Model M122 for $30+ shipping. Just needs a Soarer's converter and you're good to go!
(That and a good cleaning.... If you give me time I can clean it and make sure it works)
- ZedTheMan
Hey, it's all good! The battleship sized ones aren't for every desk, haha! Best of luck.
- fohat
- Elder Messenger
- DT Pro Member: 0158
Ignore the haters and buy a new Unicomp with native USB, warranty, and Windows keys.
If it turns out that you like Model Ms, then get into vintage stuff.
I agree. Unicomp is a decent one stop shop for getting into this. And you’re in America, so shipping won’t kill the deal.
My beef with Unicomp is their complacency. They’re an old firm on its way out. Buy from them while you can, but don’t count on them being around as long as your board itself can last.
- elecplus
Not necessarily. I sell tested and cleaned M101s for $100. And I have a slew of terminal M102/103 for $45 or less. But $100 will no longer get you an SSK. 4 years ago I was stupid and sold them for $25.
- snacksthecat
- Main keyboard: SSK
- DT Pro Member: 0205
I have a Model M that I could clean up and convert to USB. It'd be $50 if you're interested (no factory warranty and no windows key though
). I'll send you a photo if this is something you'd might like. From the ebay photos it looked like it was in fine shape but I need to take it apart and check out the rivets.
so do you own it or are you going to buy it and repair it for $50 + the cost of the keyboard? I don't understand what you mean.snacksthecat wrote: I have a Model M that I could clean up and convert to USB. It'd be $50 if you're interested (no factory warranty and no windows key though). I'll send you a photo if this is something you'd might like. From the ebay photos it looked like it was in fine shape but I need to take it apart and check out the rivets.
- snacksthecat
I own it.Cherryisgarbage wrote:so do you own it or are you going to buy it and repair it for $50 + the cost of the keyboard? I don't understand what you mean.snacksthecat wrote: I have a Model M that I could clean up and convert to USB. It'd be $50 if you're interested (no factory warranty and no windows key though). I'll send you a photo if this is something you'd might like. From the ebay photos it looked like it was in fine shape but I need to take it apart and check out the rivets.
You can pay me $50 and you can own it (at which point, I will no longer own it).
oh. I just didn't understand what you meant by "From the ebay photos it looked like it was in fine shape"snacksthecat wrote:I own it.Cherryisgarbage wrote:so do you own it or are you going to buy it and repair it for $50 + the cost of the keyboard? I don't understand what you mean.snacksthecat wrote: I have a Model M that I could clean up and convert to USB. It'd be $50 if you're interested (no factory warranty and no windows key though). I'll send you a photo if this is something you'd might like. From the ebay photos it looked like it was in fine shape but I need to take it apart and check out the rivets.
- elecplus
https://www.elecshopper.com/ibm-1395300 ... epair.html This is an M2. Shorter travel, lighter weight board. They are a real PITA to take apart. The tabs on the case tend to be brittle and break. The capacitors on the controller are notorious for going bad. Which is why I do not repair them and sell for a little more $.
M2s are nice, when they work. I’m quite partial to mine. They’re the most underrated buckling spring of all.
Sure, I’m not past pissing on a few companies, either; yet Cherry isn’t often among them. I’m not much into their switches, let alone their current keyboards, either. But as long as you like linears (yes, I know you don’t!) they’re back to being half decent of late. Maybe all the recent profit has woken them up a bit!
No one switch or firm should be the keyboard monoculture, that’s where we agree. Cherry’s hardly that. They’re more like IBM back in the PC days: their platform got away from them.
Kinda makes you wonder why it wasn’t always yours!
- Dingster
- Main keyboard: Novatouch
- Main mouse: MX518
Yes, I dont understand all the hate that model M2's get, they are a lovely keyboard (when they work ofc).Muirium wrote: M2s are nice, when they work. I’m quite partial to mine. They’re the most underrated buckling spring of all.
- swampangel
- fohat
- Elder Messenger
- digital_matthew
- Main mouse: It's a Secret.
I agree. Although the M2 is a nice board, it'll almost certainly need new capacitors and/or a membrane cleaning. A Model M will probably be in good working order and is easier to take apart and clean.
- Darkshado
- DT Pro Member: 0237
Given your budget and location you could do as Fohat suggested and simply buy a new Classic from Unicomp. As he said, comes with a warranty, native USB and Windows keys. (I'd recommend the "103 key layout" over the 104 for aesthetic considerations.)
If you'd rather buy vintage, you can't go wrong with a Model M. Without having to hunt too much? Cindy.
From what I understand this would be your first buckling spring board; you'll get a much more representative sample of the lineup with an M than an M2. Should you also get an M2? If you can live with its documented flaws and get a complete one for cheap, sure. Its key feel is still better than a lot of what's out there.
- ZedTheMan
I say go for Snacksthecat's offer if you're open to an original M. It's a good deal and he is well known around here.
