Difference with a HYBRID MECHANICAL keyboard.
shak100a
- Main keyboard: Cherry
- Main mouse: chery
- Favorite switch: cherry
Hi
Does anybody know what is the difference between a hybrid mechanical keyboard and full blown mechanical keyboard.
The prices seem very high on mechanical keyboards but can get the 1stplayer hybrid keyboard for around £20
https://www.novatech.co.uk/products/1st ... n=products
https://madoffers.co.uk/products/fire-d ... k-7-colour
- stratokaster
- Main keyboard: Filco Minila Air
- Main mouse: Contour Unimouse WL / Apple Magic Trackpad 2
- Favorite switch: Alps SKCM Green
The description mentions that only WASD and arrow keys have swappable keycaps. I suspect only those keys are mechanical on this keyboard, the rest are probably rubber domes.
- kbdfr
- The Tiproman
- DT Pro Member: 0010
https://www.tweaktown.com/reviews/7548/ ... index.htmlAnother keyboard crossed our desk […] but this time, things are a bit different inside. Where the […] were all mechanical switch-based products, and the […] was based on rubber dome switches, as we look at this latest keyboard, we find that this time around they are offering a keyboard that is opting to use hybrid mechanical switches. This means that […] has moved to something along the lines of the […] hybrid switches […]
Those who aren't familiar with […] what constitutes a hybrid switch on any level, let us try to get you up to speed here. Essentially the internals of these keyboards is based on rubber dome switches and a plastic contact pad that registers each keystroke. What makes these switches hybrid is the fact that above the rubber dome, there is a plunger between the keycap and the rubber dome switch. This type of switch tends to offer a mechanical switch feel, but without the click and clack associated with most of them. At the same time, hybrid switches have a feel all of their own, unlike any mechanical switch we have been able to test so far. […]
- stratokaster
Ah, so those are simply domes with sliders.
- stratokaster
Yes, some of them were mechanical: wiki/Dell_AT101
This was my first mechanical keyboard, and while its later versions (with Alps SKCM Black switches) are not very highly regarded, they're still a lot better than anything with Cherry MX Brown inside
- Darkshado
- DT Pro Member: 0237
LTT has a video about one of those "mem-chanical" boards... the review is not good:
- abrahamstechnology
- DT Pro Member: 0212
The Model M is technically a "hybrid mechanical"
- DT Pro Member: 0011
I would personally not call buckling-spring-on-membrane a "hybrid". "Semi-mechanical" maybe.
The bottom of the mechanism flips the foot which presses downwards. The membrane is just the press sensor.
A "hybrid" is a combination of two things that are not considered to belong together, not just a combination of two parts.
If the Model M had used the flippers of the Model F, perhaps with a nub of some kind as adapter, then it would have been a hybrid. But the Model M's feet were specifically designed to press down a membrane. Hence, not a hybrid.
But the aforementioned Cooler Master board is a spring-over-membrane with a Space Invaders-like clicker.Findecanor wrote: I would personally not call buckling-spring-on-membrane a "hybrid". "Semi-mechanical" maybe.
- vometia
- irritant
- Main keyboard: Durrr-God with fancy keycaps
- Main mouse: Roccat Malarky
- Favorite switch: Avocent Thingy
- DT Pro Member: 0184
The first Model M keyboard I used (and first keyboard I really liked) had a Dell badge on it. I guess it was probably actually manufactured by Lexmark, though not entirely sure: this would've been '97-ish.
