Tipro MID128 Cherry MX brown matrix keyboard
geekabit
09 Oct 2018, 15:17
I was cleaning out the cupboards and found a keyboard I had forgotten about. This is a Tipro MID128 matrix keyboard, with all the Cherry MX blacks removed. As an experiment I fitted Cherry MX browns where I needed them. So I could have both the programmable functionality of the Tipro and the proper brown switches. The keyboard works a charm, but I am no longer using it. There are gaps where no keys are fitted. You can either solder those yourself, and choose which switches to fit, or I can solder them for you.
The PS/2 cable is fixed on this model. There is a Pharmatechnik logo on the upper right corner.
Looking for 25 Euro (plus a bit more if I have to use switches from my stock).
Shipping within the Netherlands: 7 Euro
Shipping within Europe: 16 Euro
Shipping rest of the world: 25 Euro
Pick up: free
If you can find cheaper shipping (ca. 1.5kg) I could use that as well.
Return to “For sale”
