I grabbed an IBM model M terminal version. I love big keyboards with lots of function keys; I already own a 1987 Cherry MX Black Nixdorf thing for few years which has impressive 30 F-keys. (Sadly for a long time I couldn't use it, because I broke the cable and didn't know to repair it, for now I just connected and isolated the wires -- need to get into soldering). I also came to like those plus-shaped arrow clusters.
...Somehow I thought I could use my DIN->PS/2 adapter for connecting the M, but it actually has the dreaded 240 degrees plug. I ordered parts for my own Soarer's converter, since importing it ready-made from the US would cost more that the keyboard itself. But I also have a bigger problem. It's an old M with DIP switch, and I'm not sure how it influences my chances of getting this to work.
Some history of this keyboard. The main sticker on the back is completely destroyed, but the plastic was made in September 1985 and the backplate in January 1986, in the UK, part number 1389137. I wasn't aware it is such an early specimen. Some traces inside suggest that someone may have spilled a liquid inside, but I don't want to think about it for now
Anyway, I found a strange device inside with numbers and switches. Initially I thought that it may be some kind of lock (like you can't use the keyboard if you don't know the passcode), but apparently it's a "DIP switch" for selecting scan codes, if I'm correct.
I made some photos of what it looks like. I didn't touch the mini-switches and they are as they arrived: 1, 2, 3, 8 are "on". And luckily I documented my disassembly so I'm sure that I re-plugged it as it was: pins A2-A7 and B2-B5 connected to the switch, B6 loose, B7 with its own jumper. But two wires going from the switch went completely loose. Each of the mini-switches has its own connection alright, the loose ones are at the bottom of the plug and on the other side of the switch (I hope it's somewhat visible on the photos). I don't really know that much about electronics, but I suspect that these loosened wires close the circuits for the switch to work (?).
Now, I would get your opinions. Do I have to reconnect those wires? Could I just unplug the DIP switch entirely and expect the board to somehow work? Are there some better settings of these switches? As I said earlier, I plan on trying this board with a Soarer's converter. (But if making my own passive dumb adapter for PS/2 would be somehow possible, I'd also like to know it!)
