stuff
- scottc
Kailh's response is quite scummy, trying to shift the blame off of themselves to anyone else.
I applaud NovelKeys' transparency here though, they are really doing a great job.
- abrahamstechnology
- DT Pro Member: 0212
KBDFans also removed the BOX switches from their site.
- chuckdee
- Main keyboard: Clueboard/RS Ver.B
- Main mouse: Logitech g900
- DT Pro Member: 0151
- Elrick
- Main mouse: MX518
Don't forget that Cherry Corp did the very same thing of distributing "Scratchy" switches across their whole range yet never accepted any returns with any of them.
The retail channel just got rid of them by selling all the defect switches to customers who bore their failure and complete resentment.
This is common business practice in the 21st century, make dodgy crap and distribute the broken items quickly though the retail chains. That is why our land fills are running out of space, even here in Convict Town
- Wodan
- ISO Advocate
- Main keyboard: Intense Rotation!!!
- Main mouse: Logitech G903
- Favorite switch: ALL OF THEM
Absolutely! Those Cherry switches were CLEARLY out of spec. They were in fact so scratchy that the soldering joints on some keyboards broke from the vibration. The smoothnes of their switches is specified as "Juicy MILF" when they really delivered switches there felt like Uma Thurman in a coma!Elrick wrote: Don't forget that Cherry Corp did the very same thing of distributing "Scratchy" switches across their whole range yet never accepted any returns with any of them.
This is common business practice in the 21st century, make dodgy crap and distribute the broken items quickly though the retail chains. That is why our land fills are running out of space, even here in Convict Town.
Stop making a fool of yourself. You're comparing clearly out-of-spec products with products that you personally don't enjoy. We've been getting an in-spec product from Cherry at all times (exception see below) no stems busted no builds ruined.
One thing that DID in fact bother me though was when Cherry was delivering the switches for the community MX Silent Black GB and accidentally put in MX Red springs and THEN refused to take responsibility.
- Khers
- Main keyboard: LZ CLSh
- DT Pro Member: 0087
Technically, even those were still within spec. At least within Cherry's external set of specifications.
- Wodan
- ISO Advocate
That claim just made it worse IMO!
https://www.cherry.de/PDF/EN_CHERRY_MX1A-1xxx.pdf
+/- 30%Actuation force: 60 ± 20 cN
Cherry Fabois all over the world shocked. 300hp BMW in spec with 200hp?
Anyway, no keycaps were harmed
- Khers
I agree, those tolerances are quite hilarious, especially considering how easy it is to design a spring with certain characteristics (unless you want to mimic the sound a three decade old spring made buckling into a plastic barrell, when it was new).Wodan wrote:That claim just made it worse IMO!
- Elrick
- Main mouse: MX518
The funny thing is all those keyboards using the 'Buckling Spring' mechanism still seem to work despite being used as kitchen tops and spooge receptacles, for many years
Sometimes you really need to keep it simple for it to last a long time, suspect all this Cherry-felching will eventually die off before any Buckling Spring stops working.
And why do people have to bolt mod their boards or replace the foams? It doesn't seem like IBM had high standards regarding long term usage.
- Wodan
- ISO Advocate
The Australian Model Ms must have barrel plates made of tungsten and the Model Fs must have foam made of ... well something that doesn't rot away.
For most of us, IBM keyboards are restoration projects while Cherry keyboards from the same era tend to just work. They have no shitty foam or brittle plates. That's the facts ...
Is it worth restoring a Model F and will you get a power trip from the breaking of the springs? JAWOHL MEIN FÜHRER!!!!
But don't romanticize these boards. They have their flaws and were sold a 2x-5x the price of Cherry boards.
- DT Pro Member: 0167
I have never seen a Model M or a F that has stopped working due to rivets or foam. When you take them apart to clean them sure that foam may fall to bits. There is a reason both M and F have a higher MTBF than any electro mechanical switch be it made by cherry alps or anyone else.
Then again i have never seen an old cherry board stop working, however most of the old ones i have where not made by cherry. The switches are super reliable, the build quality of there own casings are total trash.
But if someone said to me , take a model f and a mx board and type on them till they fail , i would bet on the metal contacts of the cherry wearing out before the capacitive system of the F.
- Wodan
- ISO Advocate
Capacitive BS as a contact mechanism is clearly superior to even the gold plated crosspoint contacts. That reflects in the rating of the mechanisms at 100mil vs 50mil
But the membrane BS is the IDENTICAL contact mechanism as Cherry MY rated at 25mil (IBM) or "up to 50mil" (Cherry) which is a difference from the "more than 50mil" rating of the gold crosspoint.
But when comparing the longevity of these keyboards, additional factors come into play like the common use of material that ages badly (foam, plastic barrel plates)
These G80 boards are like Russian T34 tanks. Simple but indestructable - just a few discrete switches on a PCB in a case - not much that can go bad.
I don't get it what some IBM folks keep starting the reliability discussion. When comparing a nice Montblanc Ink Pen with a ten pack of Bic Cristal, you wouldn't compare them by their reliability.
You are correct when it comes to the case construction, the quality of the plastic in the model F's ( AT excluded as that appears to use the same stuff as the M) leave a hell of allot to be desired.
And considering the price you paid for an IBM vs a cherry back in the day its impressive what you get for your money.
But i still don't rate the construction of the G80 myself, not a fan of the PCB mount stuff, its doing a massive dis service to the switch in my option. A good wyse will do the job better than G80 IMO.
And cherry does have the advantage that is a switch does fail you can just replace it and not have to take the whole bloody thing apart.
- Elrick
- Main mouse: MX518
Same here really despise the Cherry touch of only using cheap plastic casings with pcbs.
Although the WYSE keyboards come with their gawd awful layouts not representative of the standard ANSI setup so it's best avoided.
Also trying to buy any plastic keys for all those earlier WYSE keyboards are an utter arse-tearing experience, not worth the pain and misery trying to fill that keyboard with any new key-sets. If you do find any Group Buys that offer every type of key to fill your old WYSE keyboard, that super Large Space Bar will always reside in it.
Hence no matter the colour or style of key-caps, that Space bar has to stay there permanently.
- Elrick
- Main mouse: MX518
Yeah but their still plastic and pcb with NO decent Metal Plate, if you're talking about the standard Cherry made junk.
Please show us where another normal ANSI full metal plate (and casing) keyboard using any style of Cherry switch (please no Razer, Corsair, LZ, Ducky, Filco, WASD, Varmilo junk).
- Khers
Cherry MX Board 6.0 - metal plate, metal case, Cherry switches and made by Cherry - seems to fulfill all your requirements.Elrick wrote:Yeah but their still plastic and pcb with NO decent Metal Plate, if you're talking about the standard Cherry made junk.
- Wodan
- ISO Advocate
Have you completely missed the custom kit trend?
You can get a custom MX-compatible keyboard kit with your choice of plate material and a 3kg+ solid aluminium case for ~300$ in pretty much ANY layout you ever wanted to try. I've got a TX1800 that weights the same as an IBM-107.
With the recent market rates for IBM Model F keyboards, getting a decent custom from KBDfans (i.e.) is probably even cheaper than getting a Model F!
- Elrick
- Main mouse: MX518
Already had it some years ago, put it downstairs in the basement because it had their dreadful Red Switches (hate soft linears).
Too late, I'm already in with the Ellipse Model F77 keyboard hence still waiting for it to arrive to my hell hole, down under.
Also noticed KBDfans keyboards which look interesting, have never bought one yet but I might try one model to see how it is. Good that they have assembling services for their products (wish most others out there would have that very same service).
Was hoping you would provide a link to some OLDER keyboards that have an in built metal plate using either old black switches or even any blue ones (I'm not picky about which switch as long as it's NOT a red cherry switch).
- Wodan
- ISO Advocate
The problem with assembly service is the choice of switches. Most people in the custom game want to put in their hand modded, hand picked vintage switches. Chances are you'd have picked Kaihl BOX switches for your KBDfans assembly service effectively giving you a 300$ stem buster.
When looking at older keyboards things get a lot more complicated. There's a short period of time when the layouts were already kinda modern (gotta give the Model M credit for that layout) and the build quality was still over the top. Model F keyboards are a great example. As soon as their layout becomes halfway useable, they also become ungodly expensive. The only way to have a chance to grab one for less than 100$ is settling for an XT or Bigfoot with their inacceptable bottom rows.
So yeah you can try and hate on Cherry switches and find tons of constellations where they suck but in the end, they are the dominant switch in the high end custom building for a reason. I can't imagine ANY other switch has been made in nearly the same numbers and for anywhere near the same production period. Imagine Cherry let their high quality products die in the late 80s/early 90s like pretty much all other brands. We'd all be tossing each other off over the smoothness of these MX Black switches and dat butter in these MX clears.
Edit:
wiki/Cherry_G80-0693
wiki/Cherry_G80-0777
wiki/Cherry_G80-0778
I also had this TA Cherry board with plate mounted MX Blacks and a weird layout ... can't find a link.
There's some out there but they have weird layouts and are rare
Edit:
Most early 80s Cherry keyboards are plate mounted and have a metal backplate. Listing all of them would be a long task.
Just one example: wiki/Cherry_G80-0418 The cases obviously suck but those were optional things back then.
I have what i think is a late 80 unbranded 122 key. I will get some photos, but its the nicest cherry board i have ever tried. Super thick plate, ok ish caps ( thin double shot) and lovely vintage backs. MMMmmmm ! I need to get some photos of it , nothing on the wiki at all about it.
- Elrick
- Main mouse: MX518
Don't have time to build any keyboards and usually when I get back home I only have one week to pay all the bills, sort out any family issues that need sorting and of course listening to never ending complaints about everyone and the next doors.
Just no time to actually build any keyboard hence it's far easier to pay a 'business' to put in what switches they have in stock, beggars can't be choosers in this case.
Well have noticed they do sell Zealios for their keyboards at KBDfans. The single most useless switch that pretends to be "Tactile" but clearly isn't.
Although if you love Linear then they're not bad, lubed and they all use the very same Cherry fitment that doesn't GAPE any style of Key-set.
The BOX Navy is still one of my most liked switches, despite it being a Key-cap shredder. The minions all hate them but it's the most safe keyboards in the house when I'm away, no one uses them besides myself.
