Me and some friends over at the Swedish mechanical keyboard discord server ( http://mekaniskatangentbord.se/ ) recently did our first hand wired keyboards using this awesome guide: https://geekhack.org/index.php?topic=87689.0
There were however three things that weren’t 100 % clear to us after reading it: which pins that can be used on the microcontroller, how the wiring from the matrix to the microcontroller works and how to use your hand wired keyboard with an existing QMK keyboard layout. So I typed out some pointers on those three areas, and I hope that it can help some other people as well!
You can read it here:
https://johannes-jansson.github.io/proj ... split.html
Any feedback, corrections and suggestions for improvement are welcome!
I wrote a complement to “A modern hand wiring guide”
- Blaise170
- ALPS キーボード
- Main mouse: Logitech G502
- DT Pro Member: 0129
I don't really have anything to add, but want to save this thread for later.
- Main keyboard: --
- Main mouse: --
- Favorite switch: --
Thanks dood!
- Main keyboard: Hand wired let's split
- Favorite switch: Zilent 62g
- vvp
- Main keyboard: Katy/K84CS
- Favorite switch: Cherry MX
Yes. See the end of this message. There is a higher resolution picture there. And use only Ø 0.15 wire. The thinner the wire the easier it is.
