This time I'm working on fixing up a Contec (rebranded Costar) keyboard. This board has clicky amber omron switches and the board itself is nearly as yellow as the switches.
Also two things I found hilarious:
1) a dead bug
Hmmm I just had a genius (read stupid) idea. What if I left the mixture in my hot car?ScottPaladin wrote: Peroxide also works well with heat instead of UV light. It's harder to pull off with cases but keycaps can be dunked in it and gently heated. But be careful; too high a heat can soften the plastics and case them to warp, especially spacebars.
If you''re a foodie and have (or are interested in) an immersion heater for sous vide, it can double up for this purpose as well. Works a treat.
heat with peroxide is also prone to bleaching plastics. be very careful when doing this.ScottPaladin wrote: Peroxide also works well with heat instead of UV light. It's harder to pull off with cases but keycaps can be dunked in it and gently heated. But be careful; too high a heat can soften the plastics and case them to warp, especially spacebars.
