I went to use it and it's not behaving very well. I'm trying with a Soarer's converter I made which works fine with any AT keyboard that I have.
When I try with this XT, usually the keys don't register unless I mash them fairly hard. Then when they do register, they just keep repeating.
What typically goes wrong with these things? I didn't replace the foam, is that something that I should have done? Thanks!
