Here is Vincent from YMDK and today we present you Melody96, a 96-keyboard with many options (Alu-brass-acrylic).
We are finally ready to launch the GB, we decided to use google form because on our site it was too difficult to handle all the options that we are offering in this GB.
>>>ENTER GB HERE<<<
Big album with all the renders HERE: https://imgur.com/a/SrWkK (thanks /u/jkaos92 !)
Many layouts (ISO/ANSI ofc): http://i.imgur.com/SCzzBf2.png
BASE KIT 1 - $150:
Anodized aluminium top
Frosted acrylic bottom
Anodized Aluminium plate (with switch top opening holes)
PCB (QMK, different from YMD96, gold pads and higher quality, rgb)
Stabilizers, rubber feets, etc..
BASE KIT 2 - $200:
Anodized aluminium bottom
Brass Weight (coated with electroplating)
Basically kit 2 is like 1 but with alu bottom (different design as well) and a brass weight, you will not have RGB in this case.
BASE KIT 3 - $260
As above but you also get the acrylic bottom, basically you get both the bottom of the cases, the RGB version and the heavy version.
Other options:
In the form you will see many many many options, Many colors, Many many different switches (cherry, gateron, kailh, outemu..), keycaps, BRASS electroplated plate, other...
We also offer soldering service!
Contact me if you need anything via mail or write a comment in the post.
Please remember we live in a different timezone, so we might end up to answer late (especially right at post time since it is evening/night).
Contacts
[email protected]
[email protected]
Our site: http://www.ymdkey.com/
Greetings
-Vincent/YMDK
