I'll try to get it and I'll take picture of it if I do get it. At first I thought those windowes keycaps were going to be SKCL green or something like that, but Alps White ? hmmm ... Also, those alphanumeric keycaps don't look like they belong here ... If I didn't know the difference between Alps and MX, I'd said those were from a Cooler Master Novatouch
The pcb might not be the same since the MTX-124's pcb is noted "Ver 1.2" and the DSK-131 is noted "Ver 2.2". It got updated over time and the Ver2 brought simpler switches to bring costs down, making the switches clones rather than Alps ?
Note : The auction is confusing, it says all over the place that they are "original Alps" but claims they are clones ...
Though, this picture here shows a marking on the switch, I don't think it's written Alps but there is something...
about alps.tw's pages, it has been translated by a user on discord :
★★鍵盤擺位奇特的ATC-124KB★★
A keyboard with special key placements ATC-124KB
這一把鍵盤軸是15年以上老鍵盤常見的ALPS原生白軸,油墨印刷。
This keyboard is over 15 years old with ALPS “original white” switches, ink printed (legends).
之所以會介紹它的原因是它是鍵帽擺位奇特的國產中文鍵盤。
The reason I want to introduce it is because the legends on its caps are strange and in Chinese.
長寬高=520x186x40mm 淨重 1.6 kg 它是Datacomp 1992.04.14生產。
Length: Weight This was made by Datacomp in
@1~每個鍵帽都看得很清楚的正面圖
Every keycap has a clearly visible legends in the center
奇特1~英文印字位於鍵帽上部正中央
English legends are centered and near the top of the keycaps
奇特2~ㄅㄆㄇㄈㄉㄊㄋㄌㄍㄎㄏ~~~向右看齊!
(idk what the fuck this guy’s saying here)
奇特3~空白鍵(Spacebar)配置三顆,,,
There are three spacebars
沒錯,共有三個,,每顆都變小,,不容易有卡死或唧唧聲的毛病產生。
Yep, three. Each one is smaller than usual, so it’s less likely to get stuck or have smoothness issues.
奇特4~電路板預留的沒使用鍵位,由12顆假鍵帽覆蓋。
The PCB has spaces left for unused switches, covered with 12 faux keycaps.
奇特5~有備份軸的設計,那幾顆沒印字的就是備用軸,很替用家日後的維修考量。
Comes with spare switches. Those switches with legendless caps are spares. The board was designed with long term use and repair in mind.
奇特6~有複合鍵設計,譬如P右邊的@=Shift+2,@右上的﹃︿鍵=Shift+6 ......等等
There are combination keys. For example, the @ next to P is Shift+2. The key to the upper-right of @, which is ﹃︿, is Shift+6… etc.
@2~背面圖,,左右兩端個各有一個切換開關,,
On the back, there are two (DIP?) switches
左邊是286← →88 右邊是F.S+F ← → S+F.F
Left is Right is (no idea what the fuck he’s saying here)
@3~電路板線路~規劃得很整齊。
The PCB routing is very clean and organized.
@4~正面鍵帽與原生軸,連接線為五線式
The switches are PCB-mount (5 legged)
@5~背後標籤放大
The tag on the back is enlarged
謝謝收看!
Thanks for reading
