Lighting issues with Leeku L3 1800
derzemel
13 Aug 2017, 14:40
Hello all,
My Leeku L3 1800 has developed some very strange issues today.
I have kept her protected (without weight on it) for a few weeks while I have been using something else.
Today I plugged her in, and I saw this:
You would think, like I did, that some of the RGB leds are dead.
But that is not true, because I tried other colours and it works:
Using the official JigOn tool, I tried a bunch more colors and I found out that there are 2 main colours that the board refuses to display: Purple and Green Standard Colors.
What is strange, is the fact that other shades of purple/magenta and green work:
I made one more test, let see how it looks when I chose one of the RGB cycle modes in JigOn, for example RGB Effect 5
And this is the result:
I have updated the firmware, without any success.
What do you think the issue could be?
Thank you,
Derzemel
Chachał
16 Jan 2018, 01:46
Any updates? I have similar problem with my Leeku TX87 PCB
https://www.youtube.com/watch?v=nCg1n2yXKYI
derzemel
16 Jan 2018, 09:32
Chachał wrote: Any updates? I have similar problem with my Leeku TX87 PCB
Sorry about this, I forgot to update this topic
TL;DR I did fix the board.
Kin was awesome and gave me a lot of information on how to fix it.
All I needed to do was to change the first RGB led in the series that started erroring (for me it was LED number 3).
Here is a video showing the RGB Leds with the biggest issues:
Set your LED lighting to light up in a snake pattern: LED1-->LED2-->LED3-->LED4-->etc. If you are using the JigOn tool, select RGB Effect 1:
Watch for the leds that do not light up correctly.
For my case, the most visible errors were generated by the RGB LEDs 5 and 6 but they started on LED3 (it was slowly flickering and didn't light up completely, but my phone camera did not pick it up). Because the RGB led signal is sent in series, starting at LED 1-->LED2-->LED3-->etc, the issue from LED3 amplified itself until it was most visible on the LEDs 5 and 6.
All I needed to do was to change the first broken RGB LED. LED3 in my case.
So, if you have a very obvious LED erroring out, look closely at the ones before it up to LED1 to see which is the first one crapping itself and desolder it and solder a new one.
Please pay a lot of care changing the RGB LEDs because they are SMD soldered.
If the errors still persist, then you will need to change the the RGB Controller on the board. These 2 chips next to the USB connector:
I changed those 2 chips as well, even If I didn't need to, because I was an idiot and did not pay attention to all the RGB leds, only to LED5 and LED6. I contacted Kin and he was kind enough to send me a new RGB controller.
I hope this will help you fix your issue too.
snacksthecat
24 Mar 2019, 17:09
Sorry for the necro, I'm having a similar problem with my board (brand new). What type of LEDs would I need to buy if I were to try replacing them? I will do the snake test to zero-in on the problematic one(s).
derzemel
30 Mar 2019, 08:42
snacksthecat wrote: 24 Mar 2019, 17:09 Sorry for the necro, I'm having a similar problem with my board (brand new). What type of LEDs would I need to buy if I were to try replacing them? I will do the snake test to zero-in on the problematic one(s).
Well, you need to identify the LED model first. There are a lot of RGB LEDs around. For example, on the Leeku 1800 L3 I have, the smd RGB leds model is sk6812
