Hello!
I'm super new to mech keyboards, don't really have much money, so I decided to get a cheap old mech. Cleaned it, fixed some screws, but the problem is, it has a 5pin connector. I read a bit about the adapters, and found out there are passive and active ones. No idea which one I should chose.
This is an album with all the photos of the keyboard: http://imgur.com/a/h1Fxz
Sorry if this is in a wrong section, my first post here.
What kind of adapter I need for this?
- Ratfink
- Main keyboard: IBM Displaywriter
- Main mouse: CST L-Trac
From your pictures, unless someone knows exactly what keyboard that is (which they well might—I'm not exactly the most knowledgeable on Alps stuff), we can't really answer your question. A picture of the bottom of the case, especially of any switches or labels, could be helpful.
There are two common protocols that used that same connector: XT and AT. The XT protocol needs an active adapter to use on modern computers, while AT can be passively adapted to PS/2. If you want to use the keyboard with USB, you'll need an active adapter either way.
- Main mouse: Razer Naga Chroma
I will edit this post with some pictures of the bottom.
edit: http://imgur.com/aAp5r8B this is the only thing, I can open the keyboard if that will help.
- Ratfink
Wow, that's a pretty generic label.
It has lock lights, so if I had to guess, I'd say it's probably an AT keyboard. Some XT keyboards did have lock lights though, so that alone isn't a perfect indicator.
- Techno Trousers
- 100,000,000 actuations
- Main keyboard: IBM Model F-122
- Main mouse: Mionix Naos
- Favorite switch: Capacitive Buckling Spring (Model F)
- DT Pro Member: 0159
Assuming it's AT protocol, you only need a passive converter to get to PS/2. Something like this will do: https://www.amazon.com/dp/B0016RTO1M
If you need to ultimately end up with USB, I've had good luck with these "blue cube" active adapters. https://www.amazon.com/dp/B000BSJFJS
