This week we're having a look at a mechanical, programmable macropad by Focus. Another one of their cool, funky ideas!
Focus FP-21 programmable macropad review (USw LABI01)
- Daniel Beardsmore
- Main mouse: MS IMO 1.1
I assume you've had the switches apart for inspection — what's the other type they've used?
USw LABI01 is curious in that it shares the same mould numbering principle as Himake switches, yet uses different metal parts. One possibility is that they switched to a different (cheaper?) supplier of metal parts, but then there's the idea of shared/communal tooling to consider. Seeing it used side by side with another type is interesting as it may suggest a relationship between the two.
- Tuntematon
It was you! Just checked the listing. I offered $50, the seller later accepted your offer of $49.50. Interesting. Glad it went to a good home!
- Menuhin
- Main keyboard: HHKB PD-KB400BN lubed, has Hasu Bt Controller
- Main mouse: How to make scroll ring of Expert Mouse smoother?
- Favorite switch: Gateron ink lubed
Chyros, congrats for your successful defense!
Chinese from Taiwan are not short of funky ideas - connecting the main keyboard through a Numpad like Macropad. xD Perhaps we can count the number of funky ideas of vintage computer input equipments, and try to tell who have more funky ideas - the Asians e.g. CJK or the Europeans, or the North Americans.
I also want to get my hands on a programmable Alps Numpad some day, perhaps should go the Alps64 PCB design path though.
- Daniel Beardsmore
It's basically a copy of the [wiki]Cherry G80-3700[/wiki] programmable numeric keypad designed for macros only (G80-3700 can function either as a numeric keypad or as a macro pad) and with a dedicated programming key (the G80-3700 uses the Num Lock key instead).
- Main keyboard: Corsair k70 rgb rapidfire
- Main mouse: Razer DeathAdder Chroma
That looks like a part of an old IBM keyboard.xD I actually like it. It's simple but the fact that it can be programmed to basically whatever function you want is what sold me.
- Daniel Beardsmore
Curious — no word on the switches. I'm suspecting now that they were never actually examined internally.
