Korean Replacement Domes for Topre Keyboards
- Wingpad
- Main keyboard: Industrialized Model M/Orange ALPS Dell AT101W
- Main mouse: Logitech G502-RGB
- Favorite switch: Capacitive Buckling Springs
- DT Pro Member: 0162
In the past, one would have to gut an entire keyboard to change the weight of the domes in their HHKB. Now, however, it seems like there is an alternative. There are replacement domes available on eBay here in several weights, does anyone have any experience with these? I would like to upgrade my HHKB to 55g so I went ahead and ordered one... I'll make sure to post a review once I get it in.
- webwit
- Wild Duck
- Main keyboard: Model F62
- DT Pro Member: 0000
Maybe only compatible with the Hansung as listed in their store?
http://www.ebay.com/sch/Keyboards-Mice- ... 004&_sac=1
- Wingpad
- Topre Enthusiast
- Main keyboard: Realforce & Libertouch
- Main mouse: Logitech G Pro Wireless
- Favorite switch: Topre
- DT Pro Member: 0002
You probably could but it would be a pain in the arse if you had to cut each dome individually if the key pitch was different to Topre. Topre pitch is 19.05mm IIRC.
- chiptea
- Main keyboard: AT101
- Main mouse: g402
- Favorite switch: Topre/Alps Rainbow
This would actually be great to refresh the tired old domes on my Nissho. I'll wait around to see if anyone else has done it, however, since I'd not be too keen on cutting every individual dome either.
- mecano
- Main keyboard: Tipro KMX128
- Main mouse: Kensington Orbit Trackball with scroll ring
Have a look at old Commodores which feature individual domes, not sure about compatibility but maybe an interesting path to harvest parts for cheap or even design ideas.
- Laser
- emacs -nw
- Main keyboard: Plum TKL \w Topre domes (work) / Novatouch (home)
- DT Pro Member: 0180
I kinda forsee, in one-two years, we'll have strange "better" electrostatic capacitive combinations between Topre parts and their clones, in the same manner we have "Ergo Clears" and "Panda Clears" switches made from one type of MX stem and the spring from another
If the patents aren't careful enough to forbid compatible stuff, of course.
- DT Pro Member: 0011
A regular rubber dome has a rubber knob at the bottom that is used to close the circuit: either by pressing two membranes together or being of conductive rubber to close a circuit on a membrane or PCB. It is because of this knob that regular rubber dome switches have a mushy feeling when bottoming out.
The thing with Topre's domes is that they don't have these knobs at the bottom - and that is one of the things that makes them so much nicer to type on. The interior of the dome should also match the size and shape of the conical spring. The presence of a knob is also likely to interfere with the spring as the space in the centre is relatively small compared to most knobs.
The tactile "Mitsumi hybrid switch" used on some Commodore Amiga keyboards has buckling rubber sleeves around the key stem right under the keycap - which is not the same thing at all. The linear versions of the switch has coiled springs.
- XMIT
- [ XMIT ]
- DT Pro Member: 0093
These should work with Noppoo, Royal Kludge and Plum capacitive boards by the looks of it. Fascinating! I may just order in a set of 45g domes for my Noppoo board.
Zombimuncha
- Main keyboard: V80MTS-C
- Main mouse: Mionix Naos
- Favorite switch: Matias damped clicky
Interesting. If this works out it may persuade me to pony up for a Plum84.
- DT Pro Member: 0167
tempted to get a set of 55g for my novatouch but no point in opening it twice . will wait till i get my dampening rings
- Thumper
- knock knock
- Main keyboard: Whitefox
- Main mouse: Razer Deathadder Chroma
- Favorite switch: Linear Zealios | Vintage Blacks
Ordered a set (35g) for my HHKB, lets see if it fits.
Somehow i cant get used to heavy switches.
- Wingpad
So my 55g rubber domes came in - they're the same shape as the topre domes and fit right in. You have to cut the sheet to make it fit into an HHKB but you can make it happen fairly easily. That being said, these replacements domes are a great way to make a $250 board feel like a $5 rubber dome. It's really quite disappointing. They feel just as smooth as normal Topre switches but you can feel that the domes are made of a lesser material and that they're "thinner" (which makes the board a lot louder).
- Wingpad
- Thumper
- knock knock
Just got my 35g ones and modded my HHKB. Images: https://imgur.com/a/wnmCZ
Im still Not sure whether I like it or not, although it feels lighter - 35g to 45g makes sense - it feels kinda cheap, as the bump isn't that pronounced.
- Wingpad
Yeah, is it just me or is bottoming out more pronounced as well? It seems like I'm hitting the PCB without anything in between it and the slider.Thumper wrote: Just got my 35g ones and modded my HHKB. Images: https://imgur.com/a/wnmCZ
- Thumper
- knock knock
Same feeling here.Wingpad wrote:Yeah, is it just me or is bottoming out more pronounced as well? It seems like I'm hitting the PCB without anything in between it and the slider.Thumper wrote: Just got my 35g ones and modded my HHKB. Images: https://imgur.com/a/wnmCZ
attheicearcade
Copying my comment from geekhack:Wingpad wrote:Yeah, is it just me or is bottoming out more pronounced as well? It seems like I'm hitting the PCB without anything in between it and the slider.Thumper wrote: Just got my 35g ones and modded my HHKB. Images: https://imgur.com/a/wnmCZ
I think this is because the replacement domes have holes cut out on the diagonal - below where the legs of the slider are. They usually are stopped by the rubber sheet when the key is pressed. With those cutouts, maybe the slider leg is going past the sheet and hitting the PCB, or the travel is increased far enough for the keycap to hit the plate.
- Thumper
- knock knock
My Cherry profile keycaps are loud as hell, they hit the case for sure. I can test it with OEM profile later.attheicearcade wrote:Copying my comment from geekhack:Wingpad wrote:Yeah, is it just me or is bottoming out more pronounced as well? It seems like I'm hitting the PCB without anything in between it and the slider.Thumper wrote: Just got my 35g ones and modded my HHKB. Images: https://imgur.com/a/wnmCZ
- XMIT
- [ XMIT ]
I've got a 55g set for my Noppoo EC108 on the way.
I'm embarrassed to say that one of my daily drivers these days is a 55g RC930 with lubricated sliders and double shot PBT caps (the same ones that come on my Hall effect boards). It works great!
- chiptea
- Main mouse: g402
Hmm. Do the domes feel cheap like others mentioned? Have you ever used genuine 55g topre so you could compare?
- chiptea
- Main mouse: g402
- cookie
- Main keyboard: HHKB Pro 2
- Main mouse: MX Master
I will keep you guys updated but the cutouts which make the slider hit the pcb instead the silicone sheet is a real downer.
I just want to try a lighter dome sheet but keep the nice 'thok' sound
- XMIT
- [ XMIT ]
The new 55g domes are not here yet but my 55g RC930 feels much more like a 45g than a 55g Topre board. I have all three, yes.
