Anyone has model F 122 key PCB laying around?
- DMA
- Main keyboard: T420
- Main mouse: Trackpoint
- Favorite switch: beamspring
- DT Pro Member: NaN
Need good photos of both sides and closeups of connector - also both sides.
I do have the 122key model F - but I'm afraid I'll spend like 2 days assembling it back. Not mentioning all the foam crumbs!
Need it to decide how to better lay the ground out on my prospective controller.
If this is the wrong forum for that - dear admins, please move it to a correct one.
- DT Pro Member: 0167
From my experience with replacement model F controllers your controller should be grounded to the case ( plate) as well as the PCB .
- fohat
- Elder Messenger
- DT Pro Member: 0158
The controller screws onto the plate at both ends so that probably takes care of it.
There may be some helpful photos here:
workshop-f7/ibm-model-f-122-key-termina ... ansi%20122
- DMA
That goes without saying.
Basically, I'm trying to figure out what path the majority of return current will take, and will those paths be different for driving part and for sensing part or not. This will profoundly affect the wiring.
- lot_lizard
- Main keyboard: Indy SSK Model MF
- Main mouse: Logitech Anywhere MX
- Favorite switch: Beamspring
I should have several F122's with the Cindy switch haul on the Model MF project. Would you like me to send you a PCB to test with?
- DMA
wcass already sent me all the photos I need, thanks
Also I bit the bullet and disassembled mine already. Even managed to assemble it back today - ANSIfied it along the way
- alh84001
- v.001
- Main keyboard: unsaver
- Main mouse: logitech m305 / apple trackpad
- Favorite switch: BS
I was kind of intimidated by disassembling mine, but I had to do it (one column was not working). When it came to putting it all back, it was one of the more simple steps in the end. And I did it with no tools, just pressing and sliding it. I do't know if it's the same with XT/AT and others, but that was really not a boogeyman it was made out to be
- lot_lizard
Can you crack walnuts with your bare ape hands too?!?
Playing, and I agree. I just use my hands as well. Too much tension and it won't slide, easier to finesse a stubborn tab, etc. The boards with more rows are easier though since it is taller and the plate is still the same thickness (bends easier). The 4704 is the toughest I think.
Only caveat is if you replaced the foam. The old foam is pre-compressed, and helps the process a little.
- alh84001
- v.001
Actually no. Among my friends I am often singled out as that guy with hand-model hands
But back on topic, the foam in mine was the original, and I kind of expected the taller plate to be easier to work with. I'll be assembling an XT with replacement foam soon, so we'll see how I fare then
- fohat
- Elder Messenger
Old foam makes the problem mostly go away, but I think that the additional tension from a robust foam makes a significant difference in feel. I did several XTs and ATs with old foam with bare hands before I started on 122s.
Also, every board is different. Of roughly a dozen 122s that I have done, there were a couple that were particularly easy and a couple that were particularly difficult, including one that was an absolute nightmare.
It must be a function of the curvature of the plates and how much they are "sprung"
Did you put the spring for the ANSI return and backspace in the right place
- fohat
- Elder Messenger
- DMA
