It's build with Linear Zealious R1 which are stickered and lubed.
A big shoutout to Matt3o for this project. You raised the bar on a height which is really hard to top.
Khers wrote: Nice build Thumper! I'm not really a fan of how Cherry beige looks with bluegaloo, but the CMYW makes it really pretty. I do have one question for you though; why did you get Zealios when you were going to spring swap and lube them anyway? And your spacebar looks like an uncomfortable eyesore...
Any recommendations?
Sure, but if you're going to lube and spring swap, why not get Gateron clears instead? Wouldn't that be exactly the same thing? Significantly cheaper.
