JUST KIDDING EVERYONEHey folks,
If you follow reddit, here or GeekHack, you probably have come across my KUL ES-87 posts. Anyways, I am a big fan of MX Clears which is reaffirmed after my MX Blue Pok3r arrived ~2 weeks ago. Bottoming out like a madman really bugs my fingertips after a long day in the office.
Stock MX Clear I was very happy with my keyboard at it's stock level. However, after reading all the Ergo Clear posts, I began drooling over the possibilities. I wanted to at least lube my switches, fix my stabilizers and make my spacebar a little heavier. Cutting back on some of the scratchiness wouldn't hurt either.
So far, I've purchase 2 bags of SPRiT's from mechanicalkeyboards.com
68g SPRiTS To my surprise, these springs feel generally heavier than stock clear springs which is odd. I've seen Clears described as 65g/100g, 60g/80g, and so on. Regardless, these 68gs don't do much for me. They seem a bit heavier than I wanted, though I am glad I opened her up to try lubed switches. The smoothness is ... (EDIT)
78g SPRiTS These sounded ideal. Like stock MX clear, they are light at actuation and heavier at the bottoming out point. I can definitively say that they are super light at actuation... feels almost as easy to press as these MX Blues. However, I do not notice all that much resistance at the bottoming out point.
I'm now lost. Considering the amount of work involved to actually test these springs out live, I am not sure what to choose.
Has anyone tested the other heavier SPRiT springs? 80g and above? Which one is closest to the stock MX Clear, maybe slightly lighter?
I just lubed up 8x 78g Bryan-style Ergo Clears and they are wonderful. Lube does wonders!!!
