As of right now I have just ordered the PuLSE keycap set and its inspired me to create my own custom keyboard. Forewarning I have no experience whatsoever with building anything except for putting together my PC. I would also like to thank matt3o for inspiring with design that got more ideas flowing.
What I Know I Want
A TKL board with a set of dedicated arrow keys, print, delete, and function keys.
I have already purchased the PuLSE set so at least I have one part down for sure.
Switches?
Currently I own a Corsair K70 w/ MX Blues. I love them, however I've begun to notice how loud these babies can be. I've tried the MX Browns on a friends Varmillo VB87M and it just did not feel right.
I've been told to look at MX Clears, but I am definitely open to anyones suggestion that would fit my criteria for satisfying clicks.
Case
I've browsed a lot of keyboards and LOVE the Orion v2 (http://i.imgur.com/p3b3TQo.jpg) by /u/q_phazer light bar on the side of the case, but I also love having a floating key look to the board. Thankfully my father works at a company that can cut me out the Case I want and the plate that I'm currently having trouble deciding on. Preferably I would want the case also made of aluminum with a thin form factor with some small feet to allow for angled typing.
Plate
I've spent too many hours using http://www.keyboard-layout-editor.com/# an amazing keyboard editor that will also layout a CAD design after you're done. It started with deciding whether or not have a numpad
Then I had to decide whether or not to keep the F row, and where to orient the keys that I wanted in relation to the rest of the board
I then decided I wanted a more minimalistic keyboard and scratched the F-row
THEN FINALLY I BELIEVE IT WAS DONE: Note the white bar is a placeholder until I actually do a size I want for the eventually acryllic window for a LED shine through
Now I have the plate layout I just have to figure out how to use a CAD program to create the plate and a case that I am satisfied with.
I am totally open to suggestions of how to move forward or any tutorials on how to do anything past this.
Thanks!
