Hello,
I'm trying to get used to using the US international layout with dead keys for writing in Spanish as well as coding. There are some characters I miss: '¿' and '€'. Is there anyway of inputting those characters without changing the layout?
Thanks in advance.
Switching from Spanish layout to US layout.
- eliOcs
- Main keyboard: Filco with brown switch
- Favorite switch: Topre and Cherry brown
- CeeSA
- Main mouse: MM711
- DT Pro Member: 0016
maybe you give eurkey a try:
http://eurkey.steffen.bruentjen.eu/layout.html
- eliOcs
That layout makes total sense to me. Thank you very much I'll give it a try
- eliOcs
For the poker you will need to map the left windows key to ALT GR. For my use two windows keys on the poker makes no sense.mr_frag wrote:You need the alt_gr key, im in the smae sittuation than you. I want learn to type spanish in my poker with ansi layout, cause is more easy to code with ANSI layout.
