I have a better description, more photos and keymap in the Wiki
Key Tronic E03218 Keypad
- DT Pro Member: 0117
I found this interesting AT keypad from Key Tronic. Its layout is unusual. It has a somewhat standard numeric cluster plus dedicated navigation keys. In addition, there is a modifier key, Fn, that generates function key scan codes when used in combination with the numeric keys, i.e. F1, F2, etc. It also has a pass through port so that it can be connected in series with a keyboard.
- seebart
- Offtopicthority Instigator
- Main keyboard: Rotation
- DT Pro Member: 0061
Very nice, don't think I've ever seen one like it before.
- Chyros
Very nice find indeed, didn't know there were any foam and foil keypads. So is this the tactile one then? Thanks for contributing to the wiki btw
Cool little PCB too, Key Tronic F&F boards are good for that if nothing else
It a tiny bit tactile. The rubber dome does contribute a subtle buckling tactile point, but its very soft and very high. The feeling is a bit better than some Key Tronic boards I have tried. Its not nearly as bad at the bottom. But then again, the foam is in pretty good shape.
Its a sturdy little thing. I wish I could find a some female DIN-5-180 connectors like the one this thing uses that didn't cost a fortune.
- Main keyboard: Model M, dodoo dome keyboard,CherryMX numeric pad
- Main mouse: logitech Master,M705 and 3 Logitech mice
- Favorite switch: ff
I imaged that key tronic foam and foil could have the numeric pad if it possible.
That's a good news. I love the numeric pad indeed.
Thanks to share.
Thanks to share.
